[mapserver-users] Fwd: Fwd: Mapserver Fail to draw shp layer
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jul 7 06:40:00 PDT 2015
Wei,
I would suggest using gdalinfo to check on what projection the shp file
is in and verify the extents of the data. The make sure you mapfile has
the same projection info on the LAYER.
-Steve W
-------- Forwarded Message --------
Subject: Fwd: Mapserver Fail to draw shp layer
Date: Tue, 7 Jul 2015 13:35:01 +0800
To: woodbri at swoodbridge.com
hiStephen
<http://www.linkedin.com/profile/view?id=62685316&authType=name&authToken=nyFl&goback=&trk=abook_conn>
I'm sorry to interrupt you but I encounter one tricky issue for me that
I can't skip over.
I have posted to mapserver users mail group, however, it seems not
published, I can't find it at least here
<http://lists.osgeo.org/pipermail/mapserver-users/>
Thanks and BRs.
/Wei
---------- Forwarded message ----------
From: *wei cheng* <chengwei02 at gmail.com <mailto:chengwei02 at gmail.com>>
Date: 2015-07-06 9:27 GMT+08:00
Subject: Mapserver Fail to draw shp layer
To: mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
Cc: 112908676 at qq.com <mailto:112908676 at qq.com>
hi all,
I have one shp file called sensor.shp, based on which I compose mapfile
and want to view via latest Mapserver MapManager, my mapfile is:
MAP
CONFIG "MS_ERRORFILE" "d:\ms_error.txt"
DEBUG 5
DEFRESOLUTION 96
EXTENT 36623289.7484795 3778220.03563055 36627315.6082067
3780849.75397967
FONTSET "C:\\Program Files (x86)\\MapManager\\templates\\font.list"
IMAGETYPE "png24"
NAME "MS"
RESOLUTION 96
SHAPEPATH "D:\\OutSource\\Gis\\Data_new"
SIZE 843 551
STATUS ON
SYMBOLSET "C:\\Program Files (x86)\\MapManager\\templates\\symbols.sym"
UNITS METERS
OUTPUTFORMAT
NAME "png24"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT FALSE
END # OUTPUTFORMAT
OUTPUTFORMAT
NAME "print"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT FALSE
END # OUTPUTFORMAT
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
STATUS OFF
END # LEGEND
QUERYMAP
SIZE -1 -1
STATUS OFF
STYLE HILITE
END # QUERYMAP
SCALEBAR
INTERVALS 4
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
SIZE 200 3
STATUS OFF
UNITS MILES
END # SCALEBAR
WEB
METADATA
"distance_units" "MS_METERS"
"mapmanager_version" "1.0.0.0"
END # METADATA
END # WEB
LAYER
CONNECTION "Sensor.shp"
CONNECTIONTYPE OGR
DATA "Sensor"
DEBUG 5
NAME "Sensor"
STATUS ON
TILEITEM "Sensor"
TYPE LINE
UNITS METERS
CLASS
NAME "line_color"
STYLE
COLOR 255 41 9
END # STYLE
END # CLASS
END # LAYER
END # MAP
the log file has such line: msOGRFileNextShape: Returning MS_DONE (no
more shapes)
And I aslo try to load it into PostGis and the column the_geom is empty,
postgis layer can't show either.
But I load sensor.shp by SAGA (http://www.saga-gis.org/en/index.html),
it can show what I expected as follow.
So, my question is why Mapserver can't show such shp file?
Thanks for you help
论坛系统,欢迎使用http://blog.csdn.net/tiplip/article/details/10980397
