[mapserver-users] Fwd: Fwd: Mapserver Fail to draw shp layer
wei cheng chengwei02 at gmail.com
Tue Jul 7 18:42:08 PDT 2015
hi
thanks for your kind tips, it's extent I define is not correct, very shy:(
In fact, I have checked this shp file via gdalinfo before, and I have
multiple shp files but only this shp file does not match the others but I
think they are the same.
Very thankful, it works now
the right extent is:
EXTENT 36621438.0845178 3775573.64257617 36628397.8256557 3780119.79177551
the former wrong extent:
EXTENT 36623289.7484795 3778220.03563055 36627315.6082067 3780849.75397967
2015-07-07 21:40 GMT+08:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
> Wei,
> I would suggest using gdalinfo to check on what projection the shp file is
> in and verify the extents of the data. The make sure you mapfile has the
> same projection info on the LAYER.
> -Steve W
> -------- Forwarded Message --------
> Subject:        Fwd: Mapserver Fail to draw shp layer
> Date:   Tue, 7 Jul 2015 13:35:01 +0800
> From:   wei cheng <chengwei02 at gmail.com>
> To:     woodbri at swoodbridge.com
> hiStephen
> http://www.linkedin.com/profile/view?id=62685316&authType=name&authToken=nyFl&goback=&trk=abook_conn
> I'm sorry to interrupt you but I encounter one tricky issue for me that
> I can't skip over.
> I have posted to mapserver users mail group, however, it seems not
> published, I can't find it at least here
> <http://lists.osgeo.org/pipermail/mapserver-users/>
> Thanks and BRs.
> /Wei
> ---------- Forwarded message ----------
> From: *wei cheng* <chengwei02 at gmail.com <mailto:chengwei02 at gmail.com>>
> Date: 2015-07-06 9:27 GMT+08:00
> Subject: Mapserver Fail to draw shp layer
> To: mapserver-users at lists.osgeo.org <mailto:
> mapserver-users at lists.osgeo.org>
> Cc: 112908676 at qq.com <mailto:112908676 at qq.com>
> hi all,
> I have one shp file called sensor.shp, based on which I compose mapfile
> and want to view via latest Mapserver MapManager, my mapfile is:
> MAP
>    CONFIG "MS_ERRORFILE" "d:\ms_error.txt"
>    DEBUG 5
>    DEFRESOLUTION 96
> 3780849.75397967
>    FONTSET "C:\\Program Files (x86)\\MapManager\\templates\\font.list"
>    IMAGETYPE "png24"
>    NAME "MS"
>    RESOLUTION 96
>    SHAPEPATH "D:\\OutSource\\Gis\\Data_new"
>    SIZE 843 551
>    STATUS ON
>    SYMBOLSET "C:\\Program Files (x86)\\MapManager\\templates\\symbols.sym"
>    UNITS METERS
>    OUTPUTFORMAT
>      NAME "png24"
>      MIMETYPE "image/png"
>      DRIVER "AGG/PNG"
>      EXTENSION "png"
>      IMAGEMODE RGB
>      TRANSPARENT FALSE
>    END # OUTPUTFORMAT
>    OUTPUTFORMAT
>      NAME "print"
>      DRIVER "AGG/PNG"
>      EXTENSION "png"
>      IMAGEMODE RGB
>      TRANSPARENT FALSE
>    END # OUTPUTFORMAT
>    LEGEND
>      KEYSIZE 20 10
>      KEYSPACING 5 5
>      LABEL
>        SIZE MEDIUM
>        OFFSET 0 0
>        SHADOWSIZE 1 1
>        TYPE BITMAP
>      END # LABEL
>      STATUS OFF
>    END # LEGEND
>    QUERYMAP
>      SIZE -1 -1
>      STATUS OFF
>      STYLE HILITE
>    END # QUERYMAP
>    SCALEBAR
>      INTERVALS 4
>      LABEL
>        SIZE MEDIUM
>        OFFSET 0 0
>        SHADOWSIZE 1 1
>        TYPE BITMAP
>      END # LABEL
>      SIZE 200 3
>      STATUS OFF
>      UNITS MILES
>    END # SCALEBAR
>    WEB
>      METADATA
>        "distance_units"    "MS_METERS"
>        "mapmanager_version"    "1.0.0.0"
>      END # METADATA
>    END # WEB
>    LAYER
>      CONNECTION "Sensor.shp"
>      CONNECTIONTYPE OGR
>      DATA "Sensor"
>      DEBUG 5
>      NAME "Sensor"
>      STATUS ON
>      TILEITEM "Sensor"
>      TYPE LINE
>      UNITS METERS
>      CLASS
>        NAME "line_color"
>        STYLE
>          COLOR 255 41 9
>        END # STYLE
>      END # CLASS
>    END # LAYER
> END # MAP
> the log file has such line: msOGRFileNextShape: Returning MS_DONE (no
> more shapes)
> And I aslo try to load it into PostGis and the column the_geom is empty,
> postgis layer can't show either.
> But I load sensor.shp by SAGA (http://www.saga-gis.org/en/index.html),
> it can show what I expected as follow.
> So, my question is why Mapserver can't show such shp file?
> Thanks for you help
> 论坛系统,欢迎使用http://blog.csdn.net/tiplip/article/details/10980397
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150708/3ece9ff9/attachment.htm>
More information about the MapServer-users mailing list
