[mapserver-users] Very strange problem doing a query and hanging on MS 6.4.1
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jul 14 12:49:16 PDT 2015
Ans not related to apache, I can still reproduce this at the
commandline, although it is harder to find a case that fails now that I
have set TOLERANCE and TOLERANCEUNITS.
Is there a way to limit the number of features like MAXFEATURES for
drawing, only for queries?
I see in the code map->query.maxfeatures but I'm not finding a way to
set that via CGI or mapfile?
-Steve
On 7/14/2015 11:20 AM, Stephen Woodbridge wrote:
> OK, not totally solved! Things are better by explicitly setting
> TOLERANCE and TOLERANCEUNITS but I am still getting random hanging of
> processes doing queries.
> I'm wondering if this is related to apache 2.4 and the way it is setting
> up cgi-bin processes. What is the best practice for configuring apache
> 2.4 (things changed in apache 2.4 from 2.2) cgi for use with mapserver?
> I'm running Ubuntu 14.04 LTS and have these packages installed:
> apache2:amd64/trusty-security 2.4.7-1ubuntu4.4 uptodate
> apache2-bin:amd64/trusty-security 2.4.7-1ubuntu4.4 uptodate
> apache2-data:all/trusty-security 2.4.7-1ubuntu4.4 uptodate
> apache2-mpm-prefork:amd64/trusty-security 2.4.7-1ubuntu4.4 uptodate
> apache2-utils:amd64/trusty-security 2.4.7-1ubuntu4.4 uptodate
> libapache2-mod-geoip:amd64/trusty 1.2.8-2 uptodate
> libapache2-mod-mapcache:amd64/trusty 1.2.1-2 uptodate
> libapache2-mod-php5:amd64/trusty-security 5.5.9+dfsg-1ubuntu4.11 uptodate
> libapache2-mod-python:amd64/trusty 3.3.1-11ubuntu2 uptodate
> cgi-mapserver:amd64/trusty 6.4.1-2 uptodate
> libmapserver1:amd64/trusty 6.4.1-2 uptodate
> mapserver-bin:amd64/trusty 6.4.1-2 uptodate
> ls /etc/apache2/mods-enabled/
> access_compat.load  autoindex.load  geoip.load        php5.conf
> alias.load          cgi.load        mapcache.conf     php5.load
> auth_basic.load     deflate.conf    mapcache.load     python.load
> authn_core.load     deflate.load    mime.conf         setenvif.conf
> authn_file.load     dir.conf        mime.load         setenvif.load
> authz_core.load     dir.load        mpm_prefork.conf  status.conf
> authz_host.load     env.load        mpm_prefork.load  status.load
> authz_user.load     filter.load     negotiation.conf
> autoindex.conf      geoip.conf      negotiation.load
> On 7/13/2015 11:48 AM, Stephen Woodbridge wrote:
>> SOLVED: see below ...
>> According to the docs, the defaults are:
>> TOLERANCE 3
>> TOLERANCEUNITS pixels
>> and with:
>> QUERY_STRING='map=/maps/wms/bathymetry.map&mode=query&layers=model_query&mapxy=-100.98125+41.58125'
>> How is zoom calculated?
>> LAYER
>>    NAME "model_query"
>>    STATUS on
>>    TYPE raster
>>    TILEINDEX "NOAA_Coastal_Relief_Model/index.shp"
>>    TILEITEM "LOCATION"
>>    CLASS
>>      TEMPLATE "/maps/wms/pixel.value.html"
>>    END
>> END
>> Did this behavior change from 6.2.1 to 6.4.1? because it is not noted in
>> the MIGRATION-GUIDE if it did. On 6.2.1 I get the following result:
>> Content-Type: text/html
>> <HTML
>> <HEAD><TITLE>MapServer Message</TITLE></HEAD
>> <!-- MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>> SUPPORTS=SVG_SYMBOLS SUPPORTS=ICONV SUPPORTS=FRIBIDI
>> SUPPORTS=WMS_SERVER
>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
>> INPUT=GDAL INPUT=SHAPEFILE -->
>> <BODY BGCOLOR="#FFFFFF"
>> msQueryByPoint(): Search returned no results. No matching record(s)
>> found.
>> </BODY></HTML>
>> which returns very quickly.
>> I rsynced the data and the mapfile for Ubuntu 12.04 to 14.04 and
>> installed the mapserver package. Everything else appears to be working
>> without a problem except this issue.
>> SOLVED:
>> I explicitly added:
>> TOLERANCE 1
>> to my LAYER definition and now it works.
>> d# /usr/lib/cgi-bin/mapserv
>> <HTML>
>> <HEAD><TITLE>MapServer Message</TITLE></HEAD>
>> <!-- MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> OUTPUT=KML SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV
>> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
>> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
>> <BODY BGCOLOR="#FFFFFF">
>> found.
>> </BODY></HTML>
>> So it looks like maybe the defaults are not getting initialized.
>> Opened: https://github.com/mapserver/mapserver/issues/5120
>> Thanks,
>>    -Steve
>> On 7/13/2015 11:05 AM, thomas bonfort wrote:
>>> Or that could just be the number of pixels under the query point if
>>> you are zoomed out far or with a large tolerance...
>>> On 13 July 2015 at 17:01, Stephen Woodbridge <woodbri at swoodbridge.com>
>>> wrote:
>>>> Thomas,
>>>> More information:
>>>> /u/software/mapserver-rel-6-4-2/maptemplate.c:4366
>>>> 4366        for(j=0; j<lp->resultcache->numresults; j++) {
>>>> (gdb) p lp->resultcache->numresults
>>>> $7 = 2884991
>>>> this is clearly a bad value my guess is that it is not getting
>>>> initialized
>>>> to zero and assumes it will get set when some number of results are
>>>> found,
>>>> but if no results are found it is not getting set to zero. (Just a
>>>> hypothesis)
>>>> -Steve W
>>>> On 7/13/2015 10:41 AM, Stephen Woodbridge wrote:
>>>>> Thomas,
>>>>> Here is the initial backtrace afte starting it and and ^C while it is
>>>>> printing -99999 lines:
>>>>> #0  processLine (mapserv=0x609050, instr=0x7fffffffcc60 "[value_0]\n",
>>>>>       stream=0x688460, mode=9)
>>>>>       at /u/software/mapserver-rel-6-4-2/maptemplate.c:3697
>>>>> #1  0x00007ffff7a2e9cc in msReturnPage (mapserv=0x609050,
>>>>>       html=0x6612e0 "/maps/wms/pixel.value.html", mode=9,
>>>>> papszBuffer=0x0)
>>>>>       at /u/software/mapserver-rel-6-4-2/maptemplate.c:4159
>>>>> #2  0x00007ffff7a2f7ed in msReturnNestedTemplateQuery
>>>>> (mapserv=0x609050,
>>>>>       pszMimeType=0x60c8f0 "text/html", papszBuffer=0x0)
>>>>>       at /u/software/mapserver-rel-6-4-2/maptemplate.c:4385
>>>>> #3  0x00007ffff7a1f586 in msReturnTemplateQuery (mapserv=0x609050,
>>>>>       queryFormat=0x60c8f0 "text/html", papszBuffer=0x0)
>>>>>       at /u/software/mapserver-rel-6-4-2/maptemplate.c:315
>>>>> #4  0x00007ffff79f1230 in msCGIDispatchQueryRequest (mapserv=0x609050)
>>>>>       at /u/software/mapserver-rel-6-4-2/mapservutil.c:1476
>>>>> #5  0x00007ffff79f2205 in msCGIDispatchRequest (mapserv=0x609050)
>>>>>       at /u/software/mapserver-rel-6-4-2/mapservutil.c:1784
>>>>> #6  0x000000000040115b in main (argc=2, argv=0x7fffffffdf98)
>>>>>       at /u/software/mapserver-rel-6-4-2/mapserv.c:259
>>>>> I'll poke around a little more in gdb and see if I can figure out
>>>>> anything more.
>>>>> Thanks,
>>>>>     -Steve
>>>>> On 7/13/2015 4:12 AM, thomas bonfort wrote:
>>>>>> Steve,
>>>>>> please include a backtrace from gdb where you believe the infinite
>>>>>> loop is happening.
>>>>>> thomas
>>>>>> On 13 July 2015 at 01:22, Stephen Woodbridge
>>>>>> wrote:
>>>>>>> I added gdalinfo on an actual raster file below. It turns out the
>>>>>>> -99999 is
>>>>>>> the NoData Value. I would be happy to just get this value back
>>>>>>> (once), but I
>>>>>>> think something is broken and putting mapserver into an infinite
>>>>>>> loop.
>>>>>>> -Steve W
>>>>>>> On 7/12/2015 7:14 PM, Stephen Woodbridge wrote:
>>>>>>>> Hi all,
>>>>>>>> I have run into a very strange problem doing a mapserver query. I'm
>>>>>>>> upgrading a system that was running fine. The details are below.
>>>>>>>> I also
>>>>>>>> tried to put the template inside a CLASS ... END block that didn't
>>>>>>>> help.
>>>>>>>> Can anyone else reproduce something like this?
>>>>>>>> Got any ideas on how to work around it?
>>>>>>>> Thanks,
>>>>>>>>      -Steve W
>>>>>>>> Old system:
>>>>>>>> Ubuntu 12.04 LTS
>>>>>>>> SUPPORTS=PROJ
>>>>>>>> SUPPORTS=WMS_SERVER
>>>>>>>> New system:
>>>>>>>> Ubuntu 14.04 LTS
>>>>>>>> OUTPUT=KML
>>>>>>>> SUPPORTS=CAIRO
>>>>>>>> SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI
>>>>>>>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>>>>>>>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
>>>>>>>> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG
>>>>>>>> INPUT=POSTGIS
>>>>>>>> The query layer looks like this:
>>>>>>>> LAYER
>>>>>>>>      NAME "model_query"
>>>>>>>>      STATUS on
>>>>>>>>      TYPE raster
>>>>>>>>      TILEITEM "LOCATION"
>>>>>>>> END
>>>>>>>> cat "/maps/wms/pixel.value.html"
>>>>>>>> <!-- MapServer Template -->
>>>>>>>> [value_0]
>>>>>>>> dbf_dump -info wms/data/Bathy/NOAA_Coastal_Relief_Model/index.dbf
>>>>>>>> Filename:       wms/data/Bathy/NOAA_Coastal_Relief_Model/index.dbf
>>>>>>>> Version:        0x03 (ver. 3)
>>>>>>>> Num of records: 61
>>>>>>>> Header length:  65
>>>>>>>> Record length:  256
>>>>>>>> Last change:    1995/7/26
>>>>>>>> Num fields:     1
>>>>>>>> Field info:
>>>>>>>> Num     Name            Type    Len     Decimal
>>>>>>>> 1.      LOCATION        C       255     0
>>>>>>>> dbf_dump  wms/data/Bathy/NOAA_Coastal_Relief_Model/index.dbf | head
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1035.tif
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1156.tif
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1193.tif
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1239.tif
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1261.tif
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1326.tif
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1343.tif
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1536.tif
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1557.tif
>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1801.tif
>>>>>>>> ogrinfo -so wms/data/Bathy/NOAA_Coastal_Relief_Model/index.shp
>>>>>>>> index
>>>>>>>> INFO: Open of `wms/data/Bathy/NOAA_Coastal_Relief_Model/index.shp'
>>>>>>>>          using driver `ESRI Shapefile' successful.
>>>>>>>> Layer name: index
>>>>>>>> Geometry: Polygon
>>>>>>>> Feature Count: 61
>>>>>>>> Extent: (-130.000417, 16.999583) - (-65.999599, 49.000401)
>>>>>>>> Layer SRS WKT:
>>>>>>>> (unknown)
>>>>>>>> location: String (255.0)
>>>>>>>> When I issue a query like:
>>>>>>>> The old server responded with:
>>>>>>>> <HTML>
>>>>>>>> SUPPORTS=CAIRO
>>>>>>>> SUPPORTS=WMS_SERVER
>>>>>>>> found.
>>>>>>>> </BODY></HTML>You have new mail in /var/mail/root
>>>>>>>> I get an infinite number of lines like the following on the new
>>>>>>>> server:
>>>>>>>> | head
>>>>>>>> -99999
>>>>>>>> -99999
>>>>>>>> -99999
>>>>>>>> -99999
>>>>>>>> -99999
>>>>>>>> -99999
>>>>>>>> -99999
>>>>>>>> -99999
>>>>>>>> ^C
>>>>>>> # gdalinfo wms/data/Bathy/NOAA_Coastal_Relief_Model/BSM-1156.tif
>>>>>>> Driver: GTiff/GeoTIFF
>>>>>>> Files: wms/data/Bathy/NOAA_Coastal_Relief_Model/BSM-1156.tif
>>>>>>> Size is 4801, 4801
>>>>>>> Coordinate System is:
>>>>>>> GEOGCS["WGS 84",
>>>>>>>       DATUM["WGS_1984",
>>>>>>>           SPHEROID["WGS 84",6378137,298.257223563,
>>>>>>>               AUTHORITY["EPSG","7030"]],
>>>>>>>           AUTHORITY["EPSG","6326"]],
>>>>>>>       PRIMEM["Greenwich",0],
>>>>>>>       UNIT["degree",0.0174532925199433],
>>>>>>>       AUTHORITY["EPSG","4326"]]
>>>>>>> Origin = (-102.000833330000006,41.000817329999997)
>>>>>>> Pixel Size = (0.000833330000000,-0.000833330000000)
>>>>>>> Metadata:
>>>>>>>     AREA_OR_POINT=Point
>>>>>>> Image Structure Metadata:
>>>>>>>     INTERLEAVE=BAND
>>>>>>> Corner Coordinates:
>>>>>>> Upper Left  (-102.0008333,  41.0008173) (102d 0' 3.00"W, 41d 0'
>>>>>>> 2.94"N)
>>>>>>> Lower Left  (-102.0008333,  37.0000000) (102d 0' 3.00"W, 37d 0'
>>>>>>> 0.00"N)
>>>>>>> Upper Right ( -98.0000160,  41.0008173) ( 98d 0' 0.06"W, 41d 0'
>>>>>>> 2.94"N)
>>>>>>> Lower Right ( -98.0000160,  37.0000000) ( 98d 0' 0.06"W, 37d 0'
>>>>>>> 0.00"N)
>>>>>>> Center      (-100.0004247,  39.0004087) (100d 0' 1.53"W, 39d 0'
>>>>>>> 1.47"N)
>>>>>>> Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
>>>>>>>     NoData Value=-99999
>>>>>>>     Overviews: 2401x2401, 1201x1201, 601x601, 301x301, 151x151,
>>>>>>> 76x76,
>>>>>>> 38x38
>>>>>>>> You have to ^C to kill it, even when using head. This seems like a
>>>>>>>> serious bug as it runs for about 10 mins taking 100% CPU. If you
>>>>>>>> call it
>>>>>>>> via file_get_contents() in php is hangs the request and freezea
>>>>>>>> my OL
>>>>>>>> app until it is killed or kills php reading all the data.
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
