[mapserver-users] Very strange problem doing a query and hanging on MS 6.4.1
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jul 16 18:39:35 PDT 2015
Hi Steve,
Thanks for asking. I put the details in:
https://github.com/mapserver/mapserver/issues/5120
I don't know what changed from 6.2 to 6.4 other than it seems that
all(many?) default values changed which changed the behavior significantly.
I was able to get things working by using a combination of setting
explicitly various tags in the layer.
My solution works and it turns out that I was able to fit all the
queries into two classes of problems
1. one solved with TOLERANCE 0
2. one solved with PROCESSING "RASTER_QUERY_MAX_RESULT=1" and change the
ajax handler
So now I can get to the real work I need to do. Upgrading the site was
only a side show. I always underestimate that "sure that can be done as
part of ..." always takes more time and has gotchas :)
I trace a lot of code through gdb, but there have been a lot of changes
to mapserver since I last did a deep dive into the source. I think
someone needs to look at this and probably just add a note to the
MIGRATION-GUIDE and maybe reference the issue above for details. Obvious
it has not been a problem for other people ot they found a way around it.
Thanks,
-Steve W
On 7/16/2015 2:15 PM, Lime, Steve D (MNIT) wrote:
> Steve: Did you ever track down what changed between versions? Was is
> just a default value or something more significant in the query
> processing. --Steve
> -----Original Message----- From: Stephen Woodbridge
> [mailto:woodbri at swoodbridge.com] Sent: Wednesday, July 15, 2015 8:43
> AM To: Lime, Steve D (MNIT); thomas bonfort Cc: MapserverList OSGEO
> Subject: Re: [mapserver-users] Very strange problem doing a query and
> hanging on MS 6.4.1
> On 7/14/2015 4:09 PM, Lime, Steve D (MNIT) wrote:
>> I think the map->query.maxfeatures is pretty much settable only
>> through WFS. If you're using the template driver output format you
>> can limit the number of features that way. You'd use the limit
>> property of the feature tag.
>> That said, it seems to me that you'd want to use TOLERANCE 0 with
>> whatever units you like. That means just grabbing the value of the
>> pixel the "click" falls in so you'd only ever get one value back.
> Steve,
> Thanks! From my limited test cases, setting TOLERANCE 0 seems to give
> me the old behavior. I updated #5129 to reflect this and this should
> save me a bunch of time tweaking scripts and mapfiles.
> Thanks again, -Steve W
>> Steve
>> mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
>> Stephen Woodbridge Sent: Tuesday, July 14, 2015 2:49 PM To: thomas
>> bonfort Cc: MapserverList OSGEO Subject: Re: [mapserver-users] Very
>> Ans not related to apache, I can still reproduce this at the
>> commandline, although it is harder to find a case that fails now
>> that I have set TOLERANCE and TOLERANCEUNITS.
>> Is there a way to limit the number of features like MAXFEATURES
>> for drawing, only for queries?
>> I see in the code map->query.maxfeatures but I'm not finding a way
>> to set that via CGI or mapfile?
>> -Steve
>> On 7/14/2015 11:20 AM, Stephen Woodbridge wrote:
>>> OK, not totally solved! Things are better by explicitly setting
>>> TOLERANCE and TOLERANCEUNITS but I am still getting random
>>> hanging of processes doing queries.
>>> I'm wondering if this is related to apache 2.4 and the way it is
>>> setting up cgi-bin processes. What is the best practice for
>>> configuring apache 2.4 (things changed in apache 2.4 from 2.2)
>>> cgi for use with mapserver?
>>> I'm running Ubuntu 14.04 LTS and have these packages installed:
>>> apache2:amd64/trusty-security 2.4.7-1ubuntu4.4 uptodate
>>> apache2-bin:amd64/trusty-security 2.4.7-1ubuntu4.4 uptodate
>>> apache2-data:all/trusty-security 2.4.7-1ubuntu4.4 uptodate
>>> apache2-mpm-prefork:amd64/trusty-security 2.4.7-1ubuntu4.4
>>> uptodate apache2-utils:amd64/trusty-security 2.4.7-1ubuntu4.4
>>> uptodate libapache2-mod-geoip:amd64/trusty 1.2.8-2 uptodate
>>> libapache2-mod-mapcache:amd64/trusty 1.2.1-2 uptodate
>>> libapache2-mod-php5:amd64/trusty-security 5.5.9+dfsg-1ubuntu4.11
>>> uptodate libapache2-mod-python:amd64/trusty 3.3.1-11ubuntu2
>>> uptodate
>>> cgi-mapserver:amd64/trusty 6.4.1-2 uptodate
>>> libmapserver1:amd64/trusty 6.4.1-2 uptodate
>>> mapserver-bin:amd64/trusty 6.4.1-2 uptodate
>>> ls /etc/apache2/mods-enabled/ access_compat.load autoindex.load
>>> geoip.load php5.conf alias.load cgi.load
>>> mapcache.conf php5.load auth_basic.load deflate.conf
>>> mapcache.load python.load authn_core.load deflate.load
>>> mime.conf setenvif.conf authn_file.load dir.conf
>>> mime.load setenvif.load authz_core.load dir.load
>>> mpm_prefork.conf status.conf authz_host.load env.load
>>> mpm_prefork.load status.load authz_user.load filter.load
>>> negotiation.conf autoindex.conf geoip.conf negotiation.load
>>> On 7/13/2015 11:48 AM, Stephen Woodbridge wrote:
>>>> SOLVED: see below ...
>>>> According to the docs, the defaults are:
>>>> TOLERANCE 3 TOLERANCEUNITS pixels
>>>> and with:
>>>> QUERY_STRING='map=/maps/wms/bathymetry.map&mode=query&layers=model_query&mapxy=-100.98125+41.58125'
How is zoom calculated?
>>>> LAYER NAME "model_query" STATUS on TYPE raster
>>>> TILEINDEX "NOAA_Coastal_Relief_Model/index.shp" TILEITEM
>>>> "LOCATION" CLASS TEMPLATE "/maps/wms/pixel.value.html" END END
>>>> Did this behavior change from 6.2.1 to 6.4.1? because it is
>>>> not noted in the MIGRATION-GUIDE if it did. On 6.2.1 I get the
>>>> following result:
>>>> Content-Type: text/html <HTML <HEAD><TITLE>MapServer
>>>> Message</TITLE></HEAD <!-- MapServer version 6.2.1 OUTPUT=GIF
>>>> OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG
>>>> SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
>>>> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
>>>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>>>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS
>>>> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE --> <BODY
>>>> BGCOLOR="#FFFFFF" msQueryByPoint(): Search returned no results.
>>>> No matching record(s) found. </BODY></HTML>
>>>> which returns very quickly.
>>>> I rsynced the data and the mapfile for Ubuntu 12.04 to 14.04
>>>> and installed the mapserver package. Everything else appears to
>>>> be working without a problem except this issue.
>>>> SOLVED:
>>>> I explicitly added:
>>>> TOLERANCE 1 TOLERANCEUNITS pixels
>>>> to my LAYER definition and now it works.
>>>> d# /usr/lib/cgi-bin/mapserv
>>>> <HTML> <HEAD><TITLE>MapServer Message</TITLE></HEAD> <!--
>>>> MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>>>> OUTPUT=KML SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG
>>>> SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI
>>>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>>>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
>>>> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG
>>>> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE --> <BODY
>>>> BGCOLOR="#FFFFFF"> msQueryByPoint(): Search returned no
>>>> results. No matching record(s) found. </BODY></HTML>
>>>> So it looks like maybe the defaults are not getting
>>>> initialized.
>>>> Opened: https://github.com/mapserver/mapserver/issues/5120
>>>> Thanks, -Steve
>>>> On 7/13/2015 11:05 AM, thomas bonfort wrote:
>>>>> Or that could just be the number of pixels under the query
>>>>> point if you are zoomed out far or with a large tolerance...
>>>>> On 13 July 2015 at 17:01, Stephen Woodbridge
>>>>> <woodbri at swoodbridge.com> wrote:
>>>>>> Thomas,
>>>>>> More information:
>>>>>> /u/software/mapserver-rel-6-4-2/maptemplate.c:4366
>>>>>> 4366 for(j=0; j<lp->resultcache->numresults; j++) {
>>>>>> (gdb) p lp->resultcache->numresults $7 = 2884991
>>>>>> this is clearly a bad value my guess is that it is not
>>>>>> getting initialized to zero and assumes it will get set
>>>>>> when some number of results are found, but if no results
>>>>>> are found it is not getting set to zero. (Just a
>>>>>> hypothesis)
>>>>>> -Steve W
>>>>>> On 7/13/2015 10:41 AM, Stephen Woodbridge wrote:
>>>>>>> Thomas,
>>>>>>> Here is the initial backtrace afte starting it and and
>>>>>>> ^C while it is printing -99999 lines:
>>>>>>> #0 processLine (mapserv=0x609050, instr=0x7fffffffcc60
>>>>>>> "[value_0]\n", stream=0x688460, mode=9) at
>>>>>>> /u/software/mapserver-rel-6-4-2/maptemplate.c:3697 #1
>>>>>>> 0x00007ffff7a2e9cc in msReturnPage (mapserv=0x609050,
>>>>>>> html=0x6612e0 "/maps/wms/pixel.value.html", mode=9,
>>>>>>> papszBuffer=0x0) at
>>>>>>> /u/software/mapserver-rel-6-4-2/maptemplate.c:4159 #2
>>>>>>> 0x00007ffff7a2f7ed in msReturnNestedTemplateQuery
>>>>>>> (mapserv=0x609050, pszMimeType=0x60c8f0 "text/html",
>>>>>>> papszBuffer=0x0) at
>>>>>>> /u/software/mapserver-rel-6-4-2/maptemplate.c:4385 #3
>>>>>>> 0x00007ffff7a1f586 in msReturnTemplateQuery
>>>>>>> (mapserv=0x609050, queryFormat=0x60c8f0 "text/html",
>>>>>>> papszBuffer=0x0) at
>>>>>>> /u/software/mapserver-rel-6-4-2/maptemplate.c:315 #4
>>>>>>> 0x00007ffff79f1230 in msCGIDispatchQueryRequest
>>>>>>> (mapserv=0x609050) at
>>>>>>> /u/software/mapserver-rel-6-4-2/mapservutil.c:1476 #5
>>>>>>> 0x00007ffff79f2205 in msCGIDispatchRequest
>>>>>>> /u/software/mapserver-rel-6-4-2/mapservutil.c:1784 #6
>>>>>>> 0x000000000040115b in main (argc=2, argv=0x7fffffffdf98)
>>>>>>> at /u/software/mapserver-rel-6-4-2/mapserv.c:259
>>>>>>> I'll poke around a little more in gdb and see if I can
>>>>>>> figure out anything more.
>>>>>>> Thanks, -Steve
>>>>>>> On 7/13/2015 4:12 AM, thomas bonfort wrote:
>>>>>>>> Steve, please include a backtrace from gdb where you
>>>>>>>> believe the infinite loop is happening.
>>>>>>>> -- thomas
>>>>>>>> On 13 July 2015 at 01:22, Stephen Woodbridge
>>>>>>>>> I added gdalinfo on an actual raster file below. It
>>>>>>>>> turns out the -99999 is the NoData Value. I would be
>>>>>>>>> happy to just get this value back (once), but I
>>>>>>>>> think something is broken and putting mapserver into
>>>>>>>>> an infinite loop.
>>>>>>>>> -Steve W
>>>>>>>>> On 7/12/2015 7:14 PM, Stephen Woodbridge wrote:
>>>>>>>>>> Hi all,
>>>>>>>>>> I have run into a very strange problem doing a
>>>>>>>>>> mapserver query. I'm upgrading a system that was
>>>>>>>>>> running fine. The details are below. I also tried
>>>>>>>>>> to put the template inside a CLASS ... END block
>>>>>>>>>> that didn't help.
>>>>>>>>>> Can anyone else reproduce something like this? Got
>>>>>>>>>> any ideas on how to work around it?
>>>>>>>>>> Thanks, -Steve W
>>>>>>>>>> Old system: Ubuntu 12.04 LTS
>>>>>>>>>> MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG
>>>>>>>>>> SUPPORTS=SVG_SYMBOLS SUPPORTS=ICONV
>>>>>>>>>> New system: Ubuntu 14.04 LTS
>>>>>>>>>> OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=GD
>>>>>>>>>> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>>>>>>>>>> SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV
>>>>>>>>>> The query layer looks like this:
>>>>>>>>>> TILEITEM "LOCATION" TEMPLATE
>>>>>>>>>> cat "/maps/wms/pixel.value.html" <!-- MapServer
>>>>>>>>>> Template --> [value_0]
>>>>>>>>>> dbf_dump -info
>>>>>>>>>> wms/data/Bathy/NOAA_Coastal_Relief_Model/index.dbf
>>>>>>>>>> Filename:
>>>>>>>>>> Version: 0x03 (ver. 3) Num of records: 61
>>>>>>>>>> Header length: 65 Record length: 256 Last
>>>>>>>>>> change: 1995/7/26 Num fields: 1 Field info: Num
>>>>>>>>>> Name Type Len Decimal 1. LOCATION
>>>>>>>>>> C 255 0
>>>>>>>>>> dbf_dump
>>>>>>>>>> | head NOAA_Coastal_Relief_Model/BSM-1035.tif
>>>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1156.tif
>>>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1193.tif
>>>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1239.tif
>>>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1261.tif
>>>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1326.tif
>>>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1343.tif
>>>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1536.tif
>>>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1557.tif
>>>>>>>>>> NOAA_Coastal_Relief_Model/BSM-1801.tif
>>>>>>>>>> ogrinfo -so
>>>>>>>>>> wms/data/Bathy/NOAA_Coastal_Relief_Model/index.shp
>>>>>>>>>> index INFO: Open of
>>>>>>>>>> `wms/data/Bathy/NOAA_Coastal_Relief_Model/index.shp'
using driver `ESRI Shapefile' successful.
>>>>>>>>>> Layer name: index Geometry: Polygon Feature Count:
>>>>>>>>>> 61 Extent: (-130.000417, 16.999583) - (-65.999599,
>>>>>>>>>> 49.000401) Layer SRS WKT: (unknown) location:
>>>>>>>>>> String (255.0)
>>>>>>>>>> When I issue a query like:
The old server responded with:
>>>>>>>>>> Message</TITLE></HEAD> <!-- MapServer version 6.2.1
>>>>>>>>>> OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
>>>>>>>>>> SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE
>>>>>>>>>> SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=ICONV
>>>>>>>>>> --> <BODY BGCOLOR="#FFFFFF"> msQueryByPoint():
>>>>>>>>>> Search returned no results. No matching record(s)
>>>>>>>>>> found. </BODY></HTML>You have new mail in
>>>>>>>>>> /var/mail/root
>>>>>>>>>> I get an infinite number of lines like the
>>>>>>>>>> following on the new server:
| head
>>>>>>>>>> -99999 -99999 -99999 -99999 -99999 -99999 -99999
>>>>>>>>>> -99999 ^C
>>>>>>>>> # gdalinfo
>>>>>>>>> wms/data/Bathy/NOAA_Coastal_Relief_Model/BSM-1156.tif
Driver: GTiff/GeoTIFF Files:
Size is 4801, 4801 Coordinate System is: GEOGCS["WGS
>>>>>>>>> 84", DATUM["WGS_1984", SPHEROID["WGS
>>>>>>>>> 84",6378137,298.257223563,
>>>>>>>>> AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]],
>>>>>>>>> PRIMEM["Greenwich",0],
>>>>>>>>> UNIT["degree",0.0174532925199433],
>>>>>>>>> AUTHORITY["EPSG","4326"]] Origin =
>>>>>>>>> (-102.000833330000006,41.000817329999997) Pixel Size
>>>>>>>>> = (0.000833330000000,-0.000833330000000) Metadata:
>>>>>>>>> AREA_OR_POINT=Point Image Structure Metadata:
>>>>>>>>> INTERLEAVE=BAND Corner Coordinates: Upper Left
>>>>>>>>> (-102.0008333, 41.0008173) (102d 0' 3.00"W, 41d 0'
>>>>>>>>> 2.94"N) Lower Left (-102.0008333, 37.0000000)
>>>>>>>>> (102d 0' 3.00"W, 37d 0' 0.00"N) Upper Right (
>>>>>>>>> -98.0000160, 41.0008173) ( 98d 0' 0.06"W, 41d 0'
>>>>>>>>> 2.94"N) Lower Right ( -98.0000160, 37.0000000) ( 98d
>>>>>>>>> 0' 0.06"W, 37d 0' 0.00"N) Center (-100.0004247,
>>>>>>>>> 39.0004087) (100d 0' 1.53"W, 39d 0' 1.47"N) Band 1
>>>>>>>>> Block=256x256 Type=Float32, ColorInterp=Gray NoData
>>>>>>>>> Value=-99999 Overviews: 2401x2401, 1201x1201,
>>>>>>>>> 601x601, 301x301, 151x151, 76x76, 38x38
>>>>>>>>>> You have to ^C to kill it, even when using head.
>>>>>>>>>> This seems like a serious bug as it runs for about
>>>>>>>>>> 10 mins taking 100% CPU. If you call it via
>>>>>>>>>> file_get_contents() in php is hangs the request
>>>>>>>>>> and freezea my OL app until it is killed or kills
>>>>>>>>>> php reading all the data.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> mapserver-users mailing list
>>>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> _______________________________________________ mapserver-users
>>> mailing list mapserver-users at lists.osgeo.org
