[mapserver-users] ogc:PropertyIsEqualTo behaves like PropertyIsLike with oracle
Steve.Toutant at inspq.qc.ca
Wed Jul 22 06:44:34 PDT 2015
using MapServer version 7.0.0-beta1
Steve.Toutant at inspq.qc.ca@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2015-07-22 09:43
A
Michael Smith <michael.smith.erdc at gmail.com>
cc
mapserver-users at lists.osgeo.org
Objet
Re: [mapserver-users] ogc:PropertyIsEqualTo behaves like PropertyIsLike
with oracle
CONNECTIONTYPE oraclespatial
DATA "GEOM_POIN from (select * FROM SMDVDP_STAT_METE WHERE EXTRACT(YEAR
FROM D_DEB) = 2015) USING SRID 4326"
2015-07-22 09:38
A
<Steve.Toutant at inspq.qc.ca>
cc
<mapserver-users at lists.osgeo.org>
Objet
with oracle
Same result with 1.1.0
Are you using an CONNECTIONTYPE oraclespatial or a CONNECTIONTYPE OGR to
Oracle?
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
michael.smith at usace.army.mil
Date: Wednesday, July 22, 2015 at 9:34 AM
To: Michael Smith <michael.smith.erdc at gmail.com>
Cc: <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] ogc:PropertyIsEqualTo behaves like
Michael we are using MS7 master and WFS 1.1.0
Can you try with this wfs version instead of 2.0 t osee if you get the
same results?
2015-07-22 09:32
A
cc
Objet
with oracle
When I do this on my system I get
request:
service=WFS&version=2.0.0&request=GetFeature&typeNames=gridws_pointcloud&Filter=<Filter><PropertyIsEqualto%20MatchCase="FALSE"><PropertyName>FILE_NAME</PropertyName><Literal>test2.las</Literal></PropertyIsEqualTo></Filter>
[Wed Jul 22 09:26:31 2015].885667 got a IEQ comparison
[Wed Jul 22 09:26:31 2015].885676 closing RE comparison
[Wed Jul 22 09:26:31 2015].885681 msOracleSpatialLayerWhichShapes was
called.
[Wed Jul 22 09:26:31 2015].885704 msOracleSpatialLayerWhichShapes. Using
this Sql to retrieve the data: SELECT COLLECT_ID, COLLECTION, FILE_NAME,
DATE_LOADED, PC_ID, X, Y, FILE_SIZE_MB, COLLECTDATE, DOWNLOAD_URL,
SENSOR_NAME, rownum, geom WHERE ( REGEXP_LIKE( FILE_NAME, 'test2.las','i'
) ) AND SDO_FILTER( geom, MDSYS.SDO_GEOMETRY(2003, :srid,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates ),'querytype=window')
= 'TRUE'
This shows that its translating the PropertyIsEqualTo with MatchCase false
to a regexp_like case insensitive query with no wildcards. Not sure why
you wouldn't get the same thing.
Mike
Michael Smith
US Army Corps
Date: Wednesday, July 22, 2015 at 9:13 AM
Thanks for your help, here is the log
Steve
ul 22 08:14:09 2015].892715 msOracleSpatialLayerWhichShapes. Bind values:
srid:4326 minx:-91.320741 miny:41.948470 maxx:-45.679259 maxy:63.664769
[Wed Jul 22 08:14:09 2015].894113 msOracleSpatialLayerWhichShapes bind by
name and object.
[Wed Jul 22 08:14:09 2015].894134 msOracleSpatialLayerWhichShapes name and
object now bound.
[Wed Jul 22 08:14:10 2015].77889 mapserv request processing time
(msLoadMap not incl.): 0.203s
[Wed Jul 22 08:14:10 2015].77903 msOracleSpatialLayerClose was called.
Layer: 0x1308650, Layer name: SMDVDP_STAT_METE
[Wed Jul 22 08:14:10 2015].78084
msConnPoolRelease(SMDVDP_STAT_METE,USER/*************@DATABASE:1521/DEV.fadq.qc,0x1481850)
[Wed Jul 22 08:14:30 2015].200042 CGI Request 38 on process 14430
[Wed Jul 22 08:14:30 2015].200197 msOracleSpatialLayerOpen called with:
GEOM_POIN from (select * FROM SMDVDP_STAT_METE WHERE EXTRACT(YEAR FROM
D_DEB) = 2015) USING SRID 4326 (Layer pointer 0x142bbe0)
[Wed Jul 22 08:14:30 2015].200215
msConnPoolRequest(SMDVDP_STAT_METE,USER/*************@DATABASE:1521/DEV.fadq.qc)
-> got 0x1481850
[Wed Jul 22 08:14:30 2015].208656 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Jul 22 08:14:30 2015].208676 msOracleSpatialLayerGetItems was called.
[Wed Jul 22 08:14:30 2015].209323 msOracleSpatialLayerInitItemInfo was
called.
[Wed Jul 22 08:14:30 2015].209369 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Jul 22 08:14:30 2015].209374 msOracleSpatialLayerClose was called.
Layer: 0x142bbe0, Layer name: SMDVDP_STAT_METE
[Wed Jul 22 08:14:30 2015].209396
[Wed Jul 22 08:14:30 2015].210875 msOracleSpatialLayerOpen called with:
[Wed Jul 22 08:14:30 2015].210889
-> got 0x1481850
[Wed Jul 22 08:14:30 2015].218325 msOracleSpatialLayerOpen called with:
[Wed Jul 22 08:14:30 2015].218345 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Jul 22 08:14:30 2015].218354 msOracleSpatialLayerGetItems was called.
[Wed Jul 22 08:14:30 2015].218946 msOracleSpatialLayerInitItemInfo was
called.
[Wed Jul 22 08:14:30 2015].218980 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Jul 22 08:14:30 2015].218985 msOracleSpatialLayerClose was called.
[Wed Jul 22 08:14:30 2015].219003
[Wed Jul 22 08:14:30 2015].219010 msOracleSpatialLayerOpen called with:
[Wed Jul 22 08:14:30 2015].219018
-> got 0x1481850
[Wed Jul 22 08:14:30 2015].225298 msOracleSpatialLayerEnablePaging was
called.
[Wed Jul 22 08:14:30 2015].225318 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Jul 22 08:14:30 2015].225328 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Jul 22 08:14:30 2015].225334 msOracleSpatialLayerGetItems was called.
[Wed Jul 22 08:14:30 2015].225868 msOracleSpatialLayerInitItemInfo was
called.
[Wed Jul 22 08:14:30 2015].225892 msOracleSpatialLayerInitItemInfo was
called.
[Wed Jul 22 08:14:30 2015].226421 msOracleSpatialLayerTranslateFilter.
String: ("[NOM_STAT]" =*"Anto")
[Wed Jul 22 08:14:30 2015].226429 msOracleSpatialLayerTranslateFilter.
There are tokens to process
[Wed Jul 22 08:14:30 2015].226435 got a IEQ comparison
[Wed Jul 22 08:14:30 2015].226440 closing RE comparison
[Wed Jul 22 08:14:30 2015].226444 msOracleSpatialLayerWhichShapes was
called.
[Wed Jul 22 08:14:30 2015].226470 msOracleSpatialLayerWhichShapes. Us
2015-07-21 11:24
A
<Steve.Toutant at inspq.qc.ca>, <mapserver-users at lists.osgeo.org>
cc
Objet
with oracle
Steve,
When a case insensitive exact match is used, the code should use a
regexp_like constructor in Oracle with the case insensitive flag and an
exact pattern.
Can you do DEBUG 3 and show the log?
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From: <mapserver-users-bounces at lists.osgeo.org> on behalf of <
Date: Tuesday, July 21, 2015 at 10:07 AM
To: <mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] ogc:PropertyIsEqualTo behaves like
Using MS7+oracle, I apply a wfs filter PropertyIsEqualTo on a layer
attribute (string) with a truncated string, so it should returns 0
features, but it returns 1 feature.
The complete value is "Antonin". I apply the filter using "Anto"
MS7+Postgis
<wfs:Query typeName="feature:SMDVDP_STAT_METE"
srsName="EPSG:3857"><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc
"><ogc:PropertyIsEqualTo
matchCase="false"><ogc:PropertyName>NOM_STAT</ogc:PropertyName><ogc:Literal>
Anto</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter></wfs:Query>
numberOfFeatures="0" , that is ok.
Ms log: FLTLayerApplyPlainFilterToLayer(): ("[NOM_STAT]" =*"Anto")
Ms7+Oracle
srsName="EPSG:32198"><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc
numberOfFeatures="1" , BAD
Mslog: msOracleSpatialLayerTranslateFilter. String: ("[NOM_STAT]"
=*"Anto")
Is the problem MS o oracle? Should I open a Ms bug?
Regards!
_______________________________________________ mapserver-users mailing
list mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
mapserver-users mailing list
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150722/48891ed9/attachment-0001.html>
