[mapserver-users] Using a variable as a CLASSITEM
Fawcett, David (MNIT)
David.Fawcett at state.mn.us
Fri Jul 24 12:29:11 PDT 2015
Charles,
I can't remember in which version the validation requirement was added, but take a look at this page:
http://mapserver.org/cgi/runsub.html
You may need to add a validation property to your layer.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Theobald, Charles
Sent: Friday, July 24, 2015 1:53 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Using a variable as a CLASSITEM
Is it still possible to use a variable for the value of CLASSITEM? We're passing the field name to be used in the CLASSes in the URL as a variable (%dmmethod%):
CLASSITEM '%dmmethod%'
FILTER ('[type]'='County')
STATUS on
CLASS
NAME 'No Drought'
EXPRESSION ('[%dmmethod%]'='-1')
STYLE
COLOR 255 255 255
OUTLINECOLOR 20 20 20
END
END
This used to work in previous versions. There are 6 different fields that could be searched, for 6 possible values. I'd really like to avoid creating 36 classes for each layer that uses this attribute table. I am including dmmethod in a validation block in each layer trying to use this variable. Mapserver version is 6.0.3
Any suggestions would be greatly appreciated.
Thank you.
Charles Theobald
NC Division of Water Resources
charles.theobald at ncdenr.gov
919-707-9136
*E-mail correspondence to and from this address may be subject to the North Carolina Public Records Law and may be disclosed to third parties.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
