[mapserver-users] WMS service problem with mapserver mapfile layer classes
Jörg Thomsen
jt at mapmedia.de
Thu Jun 4 00:42:30 PDT 2015
Hi Goran,
> I would like from you confirmation url that you gave
http://mapserver.stat.gov.mk/cgi-bin/GDZS/wms?map=/ms4w/apps/GDZS/NAS001_op.map&GODINA=2013&
yes that's what I meant yesterday for testing it in qgis, but if you
want provide your url to others you should have a look at
http://mapserver.org/cgi/runsub.html#default-values-if-not-provided-in-the-url
Jörg
Am 03.06.2015 um 17:59 schrieb gorank:
> Hi Jorg,
> It works with you help. Thanks. Actually I had problem to show
> municipalities in qgis but your suggestion to add YEAR in service url,
> solves the problem. I use shapefile with Year as attribute name (time series
> from 2009 to 2013) so in openlayers I select year from dropdown list and in
> the map show values from the shossen column.
> is final WMS url that users should have from our side, to access our WMS
> service?
> Goran
> View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-service-problem-with-mapserver-mapfile-layer-classes-tp5208743p5208979.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
