[mapserver-users] Incompatibility at Filter - level between mapserver 6.x and the last mapserver-dev ?
Andrea Peri
aperi2007 at gmail.com
Tue Jun 9 14:40:03 PDT 2015
Unfortunately no.
Its only a typo in e-mail.
The bracket in the mapfile was correct close.
Thx
2015-06-09 12:15 GMT+02:00 Schylberg Lars <lars.schylberg at saabgroup.com>:
> It seems like You have a typing error.
> FILTER "([CODICE[ = 107)"
> Should be:
> FILTER "([CODICE] = 107)"
> /Lars
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
> Sent: den 9 juni 2015 11:34
> To: Eichner, Andreas - SID
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Incompatibility at Filter - level between mapserver 6.x and the last mapserver-dev ?
> Thx for response.
> I try this,
> FILTER "(CODICE = 107)"
> and also this
> and removing the filteritem,
> but still go in error:
> The log report this:
> [Tue Jun 9 11:29:53 2015].880265 LayerDefaultTranslateFilter():
> General error message. This data driver does not implement filter translation support [Tue Jun 9 11:29:53 2015].955070 msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
> 2015-06-09 11:06 GMT+02:00 Eichner, Andreas - SID
> <Andreas.Eichner at sid.sachsen.de>:
>> I think you should use
>> i.e. without using FILTERITEM and the leading WHERE
>>> -----Ursprüngliche Nachricht-----
>>> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
>>> bounces at lists.osgeo.org] Im Auftrag von Andrea Peri
>>> Gesendet: Dienstag, 9. Juni 2015 10:45
>>> An: mapserver-users at lists.osgeo.org
>>> Betreff: [mapserver-users] Incompatibility at Filter - level between
>>> Hi,
>>> I have just update my mapserver to the last mapserver-dev .
>>> After this update, I see an error on the filtering.
>>> In my mapfile the data configuration was originally this:
>>> CONNECTION "/path-to-spatialite-db/zz_db_tematici.sqlite"
>>> CONNECTIONTYPE OGR
>>> DATA "IFT2009"
>>> EXTENT 1554650.74 4678225.52 1771822.76 4924891.9
>>> FILTER "WHERE ([CODICE] = 107)"
>>> FILTERITEM "CODICE"
>>> The log report this error:
>>> [Tue Jun 9 10:39:46 2015].153296 msDrawMap(): rendering using
>>> outputformat named AGGA (AGG/PNG).
>>> [Tue Jun 9 10:39:46 2015].154698 msDrawMap(): WMS/WFS set-up and
>>> query, 0.001s [Tue Jun 9 10:39:46 2015].262330
>>> translation support [Tue Jun 9 10:39:46 2015].282402 msDrawMap():
>>> Layer 239 (rt_ucs.idift.rt.107), 0.128s [Tue Jun 9 10:39:46
>>> 2015].282550 msDrawMap(): Drawing Label Cache, 0.000s
>>> I'm using spatialite as db.
>>> After this error, I read this RFC:
>>> http://www.mapserver.org/ru/development/rfc/ms-rfc-91.html
>>> And try the new settings,
>>> FILTER (([FILTERITEM[ = "string") AND (CODICE = 107))
>>> but it seem don't work.
>>> I don't understand if this is an issue of the new settings with
>>> spatialite or I'm wrong something.
>>> Thx,
>>> Andrea Peri
>>> qwerty àèìòù
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
