[mapserver-users] Is this a CGI problem?
Gery
gamejihou at hotmail.com
Fri Jun 12 07:07:07 PDT 2015
vielen Dankl! Thanks a lot for that, I just added your tips and I got a new
error message, this time related to gdal:
apache log:
[Fri Jun 12 09:10:06.316827 2015] [cgi:error] [pid 6680] [client
127.0.0.1:41157] AH01215: GDAL: In GDALDestroy - unloading GDAL shared
library.
also the same appears with shp2img:
shp2img: /usr/local/lib/libgdal.so.1: no version information available
(required by /usr/lib/x86_64-linux-gnu/libmapserver.so.1)
GDAL: In GDALDestroy - unloading GDAL shared library.
test.png is empty. I have installed gdal-1.11.2 from source, mapserv -v
gives:
mapserv: /usr/local/lib/libgdal.so.1: no version information available
MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Is there a way to fix this without uninstalling and/or reinstalling gdal?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Is-this-a-CGI-problem-tp5210276p5210648.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
