[mapserver-users] Is this a CGI problem?
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jun 12 09:51:04 PDT 2015
No really, if you are installing mapserver from a package that package
defines the related package dependencies. So if you uninstall package
libgdal, the package manager removes everything dependent on that.
Anything else will get very dicey very quickly. I you are just testing
then uninstall the related packages, and rebuild them for source and
install them in someplace like /opt/tools/ that is clean. Then you can
remove the dir tree and reinstall based on packages.
Also look around for a repository that has more recent packages, than
the standard distributions.
-Steve W
On 6/12/2015 11:38 AM, Gery wrote:
> mmmm would it be a way to link mapserver directly to libgdal coming from
> source? If I uninstall gdal-related apt-get packages, mapserver et al
> get screwed, I just don't want to install all from source (ie. postgis,
> mapserver, proj, geos, etc, etc).
> ________________________________
> > Date: Fri, 12 Jun 2015 07:18:31 -0700
> > From: [hidden email] </user/SendEmail.jtp?type=node&node=5210671&i=0>
> > To: [hidden email] </user/SendEmail.jtp?type=node&node=5210671&i=1>
> > Subject: Re: Is this a CGI problem?
> > YesNo :-/
> > https://trac.osgeo.org/grass/ticket/1730
> > Similar:
> http://stackoverflow.com/questions/137773/what-does-the-no-version-information-available-error-from-linux-dynamic-linker/156387#156387
> > The problem is that you have a mixture of library version on your
> > system, e.g. installed GDAL by packagemanager and later compiled
> > yourself - on in /usr/lib and on in /usr/local/lib
> > You can try to remove the other libraries via package manager. So you
> > have only your compiled libraries later.
> > Bye, Mathias
> > [hidden email]<https:///user/SendEmail.jtp?type=node&node=5210653&i=0>
> > 1+1=10
> > You have a question? - 42 or RTFM.
> > Am 12.06.2015 um 16:07 schrieb Gery:
> > vielen Dankl! Thanks a lot for that, I just added your tips and I got
> a new
> > error message, this time related to gdal:
> > apache log:
> > [Fri Jun 12 09:10:06.316827 2015] [cgi:error] [pid 6680] [client
> > 127.0.0.1:41157] AH01215: GDAL: In GDALDestroy - unloading GDAL shared
> > library.
> > also the same appears with shp2img:
> > shp2img: /usr/local/lib/libgdal.so.1: no version information available
> > (required by /usr/lib/x86_64-linux-gnu/libmapserver.so.1)
> > GDAL: In GDALDestroy - unloading GDAL shared library.
> > test.png is empty. I have installed gdal-1.11.2 from source, mapserv -v
> > gives:
> > mapserv: /usr/local/lib/libgdal.so.1: no version information available
> > MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> > SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
> > SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI
> > SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> > SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI
> > SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL
> > INPUT=SHAPEFILE
> > Is there a way to fix this without uninstalling and/or reinstalling
> gdal?
> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Is-this-a-CGI-problem-tp5210276p5210648.html
> > Sent from the Mapserver - User mailing list archive at Nabble.com.
> > mapserver-users mailing list
> > [hidden email]<https:///user/SendEmail.jtp?type=node&node=5210653&i=1>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > [hidden email]<https:///user/SendEmail.jtp?type=node&node=5210653&i=2>
> > If you reply to this email, your message will be added to the
> > discussion below:
> http://osgeo-org.1560.x6.nabble.com/Is-this-a-CGI-problem-tp5210276p5210653.html
> > To unsubscribe from Is this a CGI problem?, click
> > here<
> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble:email.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble:email.naml-instant_emails%21nabble:email.naml-send_instant_email%21nabble:email.naml>
> View this message in context: RE: Is this a CGI problem?
> <http://osgeo-org.1560.x6.nabble.com/Is-this-a-CGI-problem-tp5210276p5210671.html>
> <http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html> at
> Nabble.com.
> mapserver-users at lists.osgeo.org
