[mapserver-users] MapScriptException error
TDS
tds at tds-net.de
Thu Jun 18 21:15:52 PDT 2015
Hello,
MapScript can't find the file. Try to use absolute path instead of
relative path, e.g. /MyWorkingDir/mapFiles/khasra.map instead of
mapFiles/khasra.map. Check also that on linux/posix system all is case
sensitive.
Bye, TDS
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 19.06.2015 um 06:13 schrieb ankur chitranshi:
> while updating map server version 5.2.3 to 6.0.3, i am facing bellow
> error,
> *Warning*: ms_newMapObj(): [MapServer Error]: msLoadMap():
> (mapFiles/khasra.map) in *C:\ms4w\Apache\htdocs\bhopalf\index.php* on
> line *26*
> *Fatal error*: Uncaught exception 'MapScriptException' with message
> 'Failed to open map file "mapFiles/khasra.map"' in
> C:\ms4w\Apache\htdocs\bhopalf\index.php:26 Stack trace: #0
> C:\ms4w\Apache\htdocs\bhopalf\index.php(26):
> ms_newMapObj('mapFiles/khasra...') #1 {main} thrown in
> *C:\ms4w\Apache\htdocs\bhopalf\index.php* on line *26*
> *kindly help me*
> *thanking you
> thanks & regards
> Ankur Chitranshi
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150619/c47a52e9/attachment.html>
