[mapserver-users] MapScriptException error
TDS
tds at tds-net.de
Fri Jun 19 01:34:34 PDT 2015
Hello,
Mapserver is moaning about line 29, so does your symbol "foo" exists?
STYLE
SYMBOL "foo"
COLOR 255 0 0
END
e.g.:
SYMBOL
NAME "foo"
TYPE ellipse
FILLED true
POINTS
10 10
END
END
Bye, TDS
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 19.06.2015 um 08:05 schrieb ankur chitranshi:
> yes sure,
> in line 18 my code is
> $map=ms_newMapObj('C:\ms4w\Apache\htdocs\bhopalf\mapFiles\khasra.map');
> and my 'khasra.map ' file code follows....
> MAP
> NAME "bhopal Map"
> IMAGECOLOR 255 255 255
> SIZE 1050 637
> IMAGETYPE PNG
> WEB
> TEMPLATE "index.php"
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp"
> END
> SCALEBAR
> INTERLACE ON
> INTERVALS 1
> LABEL
> SIZE TINY
> END
> TRANSPARENT ON
> UNITS KILOMETERS
> END
> LAYER
> NAME "BASE"
> STATUS ON
> CONNECTIONTYPE POSTGIS
> CONNECTION ""
> DATA ""
> TYPE polygon
> CLASSITEM "BASE"
> CLASS
> NAME "Data Not Available"
> STYLE
> COLOR 0 0 0
> END
> STYLE
> SYMBOL "foo"
> COLOR 255 0 0
> END
> LABEL
> COLOR 145 145 145
> SIZE medium
> END
> END
> END
> END
> my MapServer version is 6.0.3 (MS4W 3.0.6)
> thanks in advance....
> On Fri, Jun 19, 2015 at 11:18 AM, TDS <tds at tds-net.de
> <mailto:tds at tds-net.de>> wrote:
> Hi,
> can you post the lines in that file around line 18?
> Has the file correct permissions and can Apache access that file -
> e.g. no restrictions like open_basedir?
> Bye, Mathias
> 1+1=10
> Am 19.06.2015 um 07:16 schrieb ankur chitranshi:
>> Dear,
>> Still facing error....
>> *Warning*: ms_newMapObj(): [MapServer Error]: loadSymbol():
>> Parsing error near (position):(line 29) in
>> *C:\ms4w\Apache\htdocs\bhopalf\index.php* on line *18*
>> *Fatal error*: Uncaught exception 'MapScriptException' with
>> message 'Failed to open map file
>> "C:\ms4w\Apache\htdocs\bhopalf\mapFiles\khasra.map"' in
>> C:\ms4w\Apache\htdocs\bhopalf\index.php:18 Stack trace: #0
>> C:\ms4w\Apache\htdocs\bhopalf\index.php(18):
>> ms_newMapObj('C:\ms4w\Apache\...') #1 {main} thrown in
>> On Fri, Jun 19, 2015 at 9:45 AM, TDS <tds at tds-net.de
>> Hello,
>> MapScript can't find the file. Try to use absolute path
>> instead of relative path, e.g.
>> /MyWorkingDir/mapFiles/khasra.map instead of
>> mapFiles/khasra.map. Check also that on linux/posix system
>> all is case sensitive.
>> Bye, TDS
>> 1+1=10
>> Am 19.06.2015 um 06:13 schrieb ankur chitranshi:
>>> while updating map server version 5.2.3 to 6.0.3, i am
>>> facing bellow error,
>>> *Warning*: ms_newMapObj(): [MapServer Error]: msLoadMap():
>>> (mapFiles/khasra.map) in
>>> *C:\ms4w\Apache\htdocs\bhopalf\index.php* on line *26*
>>> message 'Failed to open map file "mapFiles/khasra.map"' in
>>> C:\ms4w\Apache\htdocs\bhopalf\index.php:26 Stack trace: #0
>>> C:\ms4w\Apache\htdocs\bhopalf\index.php(26):
>>> ms_newMapObj('mapFiles/khasra...') #1 {main} thrown in
>>> *kindly help me*
>>> *thanking you
>>> thanks & regards
>>> Ankur Chitranshi
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> <mailto:mapserver-users at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> thanks & regards
>> Ankur Chitranshi
> thanks & regards
> Ankur Chitranshi
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150619/20666ecc/attachment-0001.html>
