[mapserver-users] WMS from netCDF returns white/transparent image
Bill Hudspeth
bhudspeth at edac.unm.edu
Mon Jun 22 14:35:27 PDT 2015
TC
Thank you for your help...I have tried building classes into the layer definition with the same results...a white image. Also used the CLASSITEM "[pixel]" parameter. I can import the layer into QGIS, and it actually shows the colors I define in the legend, and is projected correctly, but the image is invisible....I've not seen something like this before!
Bill
----- Original Message -----
To: mapserver-users at lists.osgeo.org
Sent: Monday, June 22, 2015 9:51:16 AM
Subject: [mapserver-users] WMS from netCDF returns white/transparent image
Hello,
I am trying to generate WMS services from layers in a NetCDF file. WCS services already work well...While a WMS call does return an image (ex. PNG), it is all white or transparent, whereas a WCS call to the same layer returns an image with a range of pixel values. I have run gdalinfo on the layer to get the data range, and have tried using the data range to set the PROCESSING DIRECTIVE to scale the output (e.g. PROCESSING "SCALE=311.76470947266 ,423.52941894531 " ). I have also used the SCALE=AUTO directive, but both just return a white image. When I try using WMS on this layer in QGIS, it is correctly projected, but invisible (zoom to extents on the imported WMS layer is correct). Below is the output from gdalinfo to get the original data range, and then the mapfile entry for the layer to see how I have set this up....
gdalinfo NETCDF:"flat_sample.nc":I_lw
Band 1 Block=170x1 Type=Float32, ColorInterp=Undefined Min=311.765 Max=423.529
Minimum=311.765, Maximum=423.529, Mean=344.247, StdDev=16.599
NoData Value=9.96920996838686905e+36
Metadata:
ipw_desc=incoming thermal (long-wave) radiation
NETCDF_DIM_time=14
NETCDF_VARNAME=I_lw
standard_name=downwelling_longwave_flux_in_air
STATISTICS_MAXIMUM=423.52941894531
STATISTICS_MEAN=344.24709697293
STATISTICS_MINIMUM=311.76470947266
STATISTICS_STDDEV=16.598777681661
units=W m-2
LAYER DATA 'NETCDF:"/geodata/watershed-data/8c/8c18e10f-44b0-4462-bf4f-1c27c984aece/flat_sample.nc":I_lw'
EXTENT -116.142905556 43.7294055556 -116.137583333 43.7326972222
METADATA
"wcs_label" "downwelling_longwave_flux_in_air"
"layer_title" "downwelling_longwave_flux_in_air"
"raster_selected" "yes"
"wms_metadataurl_type" "FGDC-STD-001-1998"
"ows_keywordlist" ""
"wcs_formats" "GEOTIFF_16"
"background" "no"
"wcs_bands_description" "ISNoBal Timesteps 1-16"
"ows_abstract" "incoming thermal (long-wave) radiation"
"wcs_rangeset_name" "Timesteps"
"wms_metadataurl_href" "http://129.24.63.85//apps/vwp/datasets/05e73f4f-51d3-417c-9757-e376b5969a9c/metadata/FGDC-STD-001-1998.xml"
"wcs_bands_values" "1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16"
"legend_display" "yes"
"queryable" "no"
"wcs_rangeset_label" "netCDF flat_sample.nc"
"time_sensitive" "no"
"ows_srs" "epsg:26911"
"wcs_bands_name" "Timestep"
"wcs_bands_rangeitem" "_bands"
"ows_title" "incoming thermal (long-wave) radiation""static" "no"
"wms_metadataurl_format" "text/xml"
"wcs_bands_label" "Timestep Number"
"wcs_rangeset_axes" "bands"
"wms_encoding" "UTF-8"
"wcs_enable_request" "*"
"layer_data_units" "W m-2"
"annotation_name" "downwelling_longwave_flux_in_air: 2015-06-19 20:30:29.202558"
END # METADATANAME "downwelling_longwave_flux_in_air"
PROCESSING "CLOSE_CONNECTION=DEFER"
#PROCESSING “SCALE=AUTO”
PROJECTION
"init=epsg:26911"
END # PROJECTION
STATUS ON
TILEITEM "location"
TYPE RASTER
UNITS METERS
END # LAYER
It seems I am missing something here....would appreciate any insight into how to return a valid image in WMS....
Thanks, Bill
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
