[mapserver-users] WFS filter creates a query using a number instead of text
bteluk at gmail.com
bteluk at gmail.com
Sun Mar 1 19:32:17 PST 2015
Hi Jukka - I've tried testing your other suggestion:
OK - I've tried using the OGR CONNECTIONTYPE - it no longer generates an
error message, but comes back with a null result set.
Checking the logs reveals that the error is now apparently being pushed
further back up the stack - eg the Postgres logs are clear (strangely) but
the MapServer debug log reports an error as follows:
I guess effectively the same error as before - there's no quoting in the
string literal (not sure why the Postgres log shouldn't still report this
error...?)
Testing the OGR config with WFS operator "PropertyIsLike", works (as did the
PostGIS driver.) I think I'll use this method for the moment as it will
work with our production system.
Thanks again!
Steve - good to know that v7 works.
View this message in context: http://osgeo-org.1560.x6.nabble.com/WFS-filter-creates-a-query-using-a-number-instead-of-text-tp5130361p5190809.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
