[mapserver-users] Reading KML
alok mathur
mathuralok.88 at gmail.com
Mon Mar 9 04:43:44 PDT 2015
PFB the KML and MAP file.
KML file
<kml xmlns="http://www.opengis.net/kml/2.2" xmlns:gx="
http://www.google.com/kml/ext/2.2" xmlns:kml="http://www.opengis.net/kml/2.2"
xmlns:atom="http://www.w3.org/2005/Atom">
<Document>
<Folder>
<name>Fibertech solution</name>
<Placemark>
<name>Westborough MSC - Build</name>
<styleUrl>#msn_ylw-pushpin4</styleUrl>
<LineString>
<tessellate>1</tessellate>
<coordinates>
-71.58570500983306,42.28745742866225,0
-71.58563778135751,42.28308954118536,0
-71.58466087108053,42.28307704913402,0
</coordinates>
</LineString>
</Placemark>
<Placemark>
<name>Westborough MSC to Westborugh</name>
<styleUrl>#msn_ylw-pushpin8</styleUrl>
<LineString>
<coordinates>
-71.62172195712955,42.27186897741407,0
-71.62194000095552,42.27189433043378,0
-71.6225634332947,42.27210480296427,0
-71.62308968672842,42.27236391420707,0
-71.62394597288645,42.27309147863262,0
-71.62737594489003,42.27740640295431,0
-71.62822373584245,42.27893783334968,0
-71.63091971519079,42.28164762788888,0
-71.63207040059587,42.28370221254578,0
-71.62599732629406,42.28418518334991,0
-71.60795611539982,42.28517668969011,0
-71.60267209851122,42.28504601944216,0
-71.60188701357249,42.28516492137062,0
-71.58850360403626,42.28849573666959,0
-71.5858004650346,42.28852197680775,0 -71.58571706491037,42.2874804233345,0
</coordinates>
</LineString>
</Placemark>
<Placemark>
<name>NEW Danbury</name>
<Camera>
<longitude>-73.45375129836707</longitude>
<latitude>41.390460041635</latitude>
<altitude>419.0806930250601</altitude>
<heading>13.43312150541231</heading>
<tilt>28.58299225276625</tilt>
<roll>-0.685026358787494</roll>
<gx:altitudeMode>relativeToSeaFloor</gx:altitudeMode>
</Camera>
<styleUrl>#msn_ylw-stars</styleUrl>
<Point>
<gx:drawOrder>1</gx:drawOrder>
<coordinates>-73.45404626023216,41.3929335947184,0</coordinates>
</Point>
</Placemark>
</Folder>
</Document>
</kml>
MAP
MAP
NAME "QGIS-MAP"
# Map image size
SIZE 500 400
UNITS meters
EXTENT -73.454046 41.392934 -71.584661 42.288522
#FONTSET './fonts/fonts.txt'
#SYMBOLSET './symbols/symbols.txt'
#PROJECTION
# 'proj=longlat'
# 'datum=WGS84'
# 'no_defs'
#END
PROJECTION
"init=epsg:4326"
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME "png"
DRIVER GD/PNG
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
TRANSPARENT ON
END
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH "/tmp/ms_tmp/"
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL "/ms_tmp/"
# WMS server settings
METADATA
"wms_enable_request" "*"
"wms_srs" "EPSG:900913 EPSG:4326 EPSG:3857 EPSG:2154 EPSG:310642901
EPSG:4171 EPSG:310024802 EPSG:310915814 EPSG:310486805 EPSG:310702807
EPSG:310700806 EPSG:310547809 EPSG:310706808 EPSG:310642810 EPSG:310642801
EPSG:310642812 EPSG:310032811 EPSG:310642813 EPSG:2986"
"labelcache_map_edge_buffer" "-10"
"wms_title" "osm fiber data"
"wms_onlineresource" "http://haxv-onecontrol-154/cgi-bin/mapserv?"
"ows_sld_enable" "true"
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See
#TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
END
# Start of LAYER DEFINITIONS -----------------------------
LAYER
NAME "kml_example_point"
TYPE POINT
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "doc_test.kml"
DATA "Fibertech solution"
LABELITEM "NAME"
CLASS
#NAME "Fiber Names"
STYLE
COLOR 0 0 0
# OUTLINECOLOR 255 255 255
SYMBOL 'pin.png'
SIZE 16
END
# LABEL
# SIZE TINY
# COLOR 0 0 0
# POSITION AUTO
# END
# END
END
LAYER
NAME "kml_example"
TYPE LINE
STATUS ON
CONNECTIONTYPE OGR
LABELITEM "NAME"
CLASS
NAME "Fiber Names"
STYLE
COLOR 250 0 0
#SYMBOL 'pin.png'
SIZE 6
END
LABEL
SIZE TINY
COLOR 0 0 0
POSITION AUTO
END
END
END
END
On Mon, Mar 9, 2015 at 5:10 PM, alok mathur <mathuralok.88 at gmail.com> wrote:
> Hi,
> I have a kml file in which there is a folder containing both Line and
> Point geometry placemarks. I want to show both line and point geomerty on
> map using mapserver. but the issue is that the data source is same. so how
> can i show the point and line data on map.
> Please help me.
> *Alok Mathur* | Software Engineer 2A | Ciena
> Mobile +91 9899413266
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150309/6656840a/attachment.html>
