[mapserver-users] KML in mapserver
    Eichner, Andreas - SID
    Andreas.Eichner at sid.sachsen.de
    Tue Mar 10 08:39:09 PDT 2015
> To get this to work You have to cast the Style value to a string also.
> DATA "SELECT Name as NAME, CAST(OGR_STYLE AS character(32)) AS STYLE FROM
> 'Fibertech solution' WHERE OGR_GEOMETRY='LINESTRING'"
Good catch, Lars! With this bit of OGR magic classification work as intented.
To summarize the relevant parts:
LAYER
	NAME "kml_line"
	TYPE LINE
	CONNECTIONTYPE OGR
	CONNECTION "doc_test.kml"
# restrict features to geometry type LINESTRING and make OGR_STYLE accessible as (class)item
	DATA "SELECT NAME, CAST(OGR_STYLE AS character(32)) AS STYLE FROM 'Fibertech solution' WHERE OGR_GEOMETRY='LINESTRING'"
	LABELITEM "NAME"
	CLASSITEM "STYLE"
	CLASS
		EXPRESSION "@msn_ylw-pushpin4"
	END
	CLASS
		EXPRESSION "@msn_ylw-pushpin8"
	END
END
> The Mapfile should something like this:
> # Start of LAYER DEFINITIONS -----------------------------
>   LAYER
> 	NAME "kml_example"
> 	GROUP LINES
> 	TYPE LINE
> 	STATUS ON
> 	CONNECTIONTYPE OGR
>             CLASSITEM "STYLE"
> 	LABELITEM "NAME"
> 	CLASS
> #	  EXPRESSION ([STYLE] = '@msn_ylw-pushpin4')
> 	  NAME "Fiber Names 4"
>       STYLE
>         COLOR 250 0 0
>        WIDTH 2.5
>      END
>       LABEL
>         SIZE TINY
>         COLOR 255 100 100
>         POSITION AUTO
>       END
>     END
>     CLASS
> #	  EXPRESSION ([STYLE] = '@msn_ylw-pushpin8')
> 	  NAME "Fiber Names 8"
>       STYLE
>         COLOR 0 255 0
> 		WIDTH 3.1
>       END
>       LABEL
>         SIZE TINY
>         COLOR 100 255 100
>         POSITION AUTO
>       END
>     END # Class
>   END # Layer
>   LAYER
>     NAME "kml_example_point"
>     GROUP PONITS
>     TYPE POINT
>     STATUS DEFAULT
>     CONNECTIONTYPE OGR
>     DATA "SELECT * FROM 'Fibertech solution' WHERE OGR_GEOMETRY='POINT'"
>     LABELITEM "Name"
>     CLASS
>       #NAME "Fiber Names"
>       STYLE
>         COLOR 0 0 255
>         SYMBOL 'circlef'
>         SIZE 16
>       END
>     END  # Class
>   END # Layer
> END # Map
More information about the MapServer-users
