[mapserver-users] Calculate length!
Schylberg Lars
lars.schylberg at saabgroup.com
Sun Mar 15 11:59:52 PDT 2015
Hi Jukka,
You were right about that is possible to calculate length of a line in a KML file in Mapserver via ogr and sqlite.
It is possible with a VRT file. I had some weekend fun learning. This will be useful in another project I am doing!
The only trouble I found, was that I could not get the relativeToVRT=1 to work when I did an inline specification of the ovf in the mapfile.
The only way to get the inline ScrDataSource specification to work was to use a full path description to the kml file location.
In most cases I like to use relative location specifications.
Shapepath specification in the mapfile didn’t help
/Lars
Example follows:
Make a ovf-file: doc_test.ovf
<OGRVRTDataSource>
<OGRVRTLayer name='doc_test'>
<SrcDataSource relativeToVRT=1>./doc_test.kml</SrcDataSource>
<SrcSQL dialect='sqlite'>
select geometry,
Name,
cast(OGR_STYLE as chartater(32)) as 'LINE_STYLE',
cast(ST_length(geometry, 4857) as integer(12)) as 'DISTANCE'
FROM 'Fibertech solution'
where ST_GeometryType(geometry) LIKE 'LINESTRING%'</SrcSQL>
</OGRVRTLayer>
</OGRVRTDataSource>
The class from the new mapfile.
LAYER
CONNECTIONTYPE OGR
CONNECTION "doc_test.ovf"
DATA 'doc_test'
NAME "kml_example"
GROUP LINES
TYPE LINE
STATUS ON
CLASSITEM "LINE_STYLE"
CLASS
EXPRESSION "@msn_ylw-pushpin4"
STYLE
COLOR 250 0 0
WIDTH 2.5
END
LABEL
TEXT ("Distance: " + '[DISTANCE]' + ' meters ' + '#' + '[Name]')
WRAP '#'
SIZE MEDIUM
COLOR 255 100 100
POSITION AUTO
END
END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150315/36275af2/attachment.html>
