[mapserver-users] Calculate length!
alok mathur
mathuralok.88 at gmail.com
Mon Mar 16 05:28:57 PDT 2015
Lars,
I have the latest OGR
GDAL 1.11.2, released 2015/02/10
Thanks!
Alok
On Mon, Mar 16, 2015 at 5:39 PM, Schylberg Lars <
lars.schylberg at saabgroup.com> wrote:
> I guess this must be a version problem. That same command runs fine on
> my osgeolive8 machine.
> ogrinfo --version
> GDAL 1.10.1, released 2013/08/26
> /Lars
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *alok mathur
> *Sent:* den 16 mars 2015 09:54
> *To:* Rahkonen Jukka (MML); mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Calculate length!
> Hi Jukka,
> When i am trying to run the above ogr command as mentioned by you I am
> getting an error
> ogrinfo -dialect sqlite -sql "select st_length(geometry) from 'Fibertech
> solution'" doc_test.kml
> INFO: Open of `doc_test.kml'
> using driver `LIBKML' successful.
> ERROR 1: In ExecuteSQL(): sqlite3_prepare(select st_length(geometry) from
> 'Fibertech solution'):
> no such function: st_length
> Please let me know what the issue is. I have installed both libsqlite3 and
> libspatialite.
> Thanks!
> Alok
*Alok Mathur* | Software Engineer 2A | Ciena
Mobile +91 9899413266
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150316/f42d5608/attachment-0001.html>
