[mapserver-users] Best integration with dynamic map information
Ahmed Aboulenein
aboulenein.ahmed at gmail.com
Tue Mar 17 12:53:42 PDT 2015
Hi Steve,
Thank you so much for the informative reply, much appreciated!
It's actually a new dataset copy every 5 minutes, it seems like replacing a
shape file would be most efficient.
We are not using MapCache, do you think it would be a good option for our
use case with this frequent updates?
Thanks again, Steve!
Best regards,
Ahmed
On Tue, Mar 17, 2015 at 8:03 PM, Lime, Steve D (MNIT) <
Steve.Lime at state.mn.us> wrote:
> I’ll let others weigh in on throughput. Seems like that should be a
> matter of resources and how much hardware you can throw at the problem. Are
> you using MapCache to serve tiles? MapServer itself is good for rendering
> tiles or more likely, metatiles.
> On thread safety MapServer itself isn’t doing any file locking. Presumably
> the OS or database is handling contention issues. I’d think the right way
> to go for data storage depends on your update process itself. If you want
> to incrementally tweak lines as new information becomes available then a
> database backend seems more reasonable – I’d think you could detect change
> easier and perhaps only retile very specific areas as a result. If instead
> you’re getting a new copy of your entire dataset every 5 minutes then
> perhaps a shapefile would work best – just replace the file and trigger
> retiling.
> Steve
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Ahmed Aboulenein
> *Sent:* Tuesday, March 17, 2015 9:19 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Best integration with dynamic map information
> Hi ALL,
> We serve traffic lines that gets updated every 5 minutes from our feeds.
> We would like to use Map Server to generate transparent tiles showing
> colored polylines of the traffic.
> I am newbie to Map Server, I got the server and workshop running and also
> I think I have some good understanding of the map file and layers concept.
> I have a question about integrating our traffic information as a data
> source to the MapServer.
> Important aspects for us:
> 1. Performance: since we are updating large areas every 5 minutes. We will
> need throughput like 10K images per second. Does this sound okay?
> 2. Threads safety: my concern what happens if while updating the source,
> the MapServer is actually rendering an image from old data. Any locks?
> I understand our options are:
> 1. Data files: such as shape files or KML files.
> 2. Database: PostGIS for example.
> 3. Service that pulls data: WMS server - I didn't dig much here.
> Thanks in advance for your help, some pointers or information to go
> further.
> Best regards,
> Ahmed
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150317/112ab1b5/attachment.html>
