[mapserver-users] Is there a way to convert a QGIS layout into a ".map" file?
    Jörg Thomsen
    jt at mapmedia.de
    Wed Mar 18 05:34:28 PDT 2015
Am 18.03.2015 um 13:20 schrieb Jeff McKenna:
> Hi Michael,
> I am with you on how important QGIS is for our workflow.
> I am aware of a MapServer plugin that is designed for QGIS 2.x, however
> I use the standalone QGIS always, so I have yet to be able to test it
> (it is however available with OSGeo4W apparently).  Give it a try:
> https://plugins.qgis.org/plugins/rt_mapserver_exporter/
it works for file-datasources and there is a wrong definition for
postgis-connections ('USING UNIQUE epsg' instead of 'USING SRID epsg').
But you should have to look at the mapfile in any case.
For finding and using the extension in qgis you have enable the
experimantal plugins.
Jörg
> The code for it lives on GitHub
> (https://github.com/faunalia/rt_mapserver_exporter), so maybe some
> passionate MapServer devs can contribute.
> -jeff
More information about the MapServer-users
