[mapserver-users] Is there a way to convert a QGIS layout into a ".map" file?
deduikertjes
DeDuikertjes at xs4all.nl
Thu Mar 19 03:58:43 PDT 2015
Rahkonen Jukka (MML) wrote
> Hi,
> The SLD output of QGIS can be good but I am not so sure how good Mapserver
> is with importing SLD. That could be tested through WMS GetMap and &SLD=
> or with &SLD_BODY= but there is no tool for converting SLD into layer
> styles as text which could be saved and used in static mapfiles, or is
> there?
> -Jukka Rahkonen-
You can do this conversion by python-mapscript. The rt_mapserver_plugins
uses this technique.
By the way the SLD export contains a bug on negative values (all ready
reported by Maarten Tromp).
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-Is-there-a-way-to-convert-a-QGIS-layout-into-a-map-file-tp5194108p5194413.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
