[mapserver-users] passing parameter to a OGRVRTDataSource layer
Martin Ouellet
geomartino at gmail.com
Wed Mar 25 13:38:29 PDT 2015
Hi all,
I'm using the virtual plugin of OGR to consume a web service who return CSV
coordinates and mapserver is able to draw the points without any problems.
The connection definition in my mapfile is something like this.
CONNECTION "<OGRVRTDataSource><OGRVRTLayer
name='select'><SrcDataSource>CSV:/vsicurl/http://<my
server>/service.php</SrcDataSource><GeometryType>wkbPoint</GeometryType><SrcLayer>select</SrcLayer><LayerSRS>WGS84</LayerSRS><GeometryField
encoding='PointFromColumns' x='PHOTO_LONGITUDE'
y='PHOTO_LATITUDE'/></OGRVRTLayer></OGRVRTDataSource>"
I would like to pass arguments to that CONNETION string so I could build
dynamic request. something like this
name='select'><SrcDataSource>CSV:/vsicurl/http://<my server>/service.php?
*param1=%PARAM1%¶m2=%PARAM2%*</SrcDataSource><GeometryType>wkbPoint</GeometryType><SrcLayer>select</SrcLayer><LayerSRS>WGS84</LayerSRS><GeometryField
I know the argument values (in my example PARAM1 and PARAM2) are OK because
I'm seeing them in the error message thrown by mapserver (see below). But
mapserver refuse to render the points:
<?xml version='1.0' encoding="UTF-8" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "
http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'photo_ownedby_all'.
msOGRFileNextShape(): OGR error. Failed to find layer 'select' on
datasource 'CSV:/vsicurl/*http://<my
server>/geophoto/select.php?PARAM1=40.886913500823205%2C-84.41259765625011&PARAM2=63.97980162961738%2C-43.587402343750284*
</ServiceException>
</ServiceExceptionReport>
Strangely, if I copy paste this url in the browser, the web service is
returning valid csv data:
*http://<my
server>/geophoto/select.php?ll=40.886913500823205%2C-84.41259765625011&ur=63.97980162961738%2C-43.587402343750284*
returned
PHOTO_LATITUDE,PHOTO_LONGITUDE
48.8099315451953,-77.0906915758454
48.8119226339273,-77.123176861499
48.8139039864207,-77.1556648776822
48.8158756013937,-77.1881556113468
48.8178374775437,-77.2206490494331
48.8171607148511,-77.2546364217682
48.8164732928131,-77.2886228129866
48.8157752119077,-77.3226082078249
48.815066472652,-77.356592590973
any thoughts?
MartinO
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150325/299a9f09/attachment.html>
