[mapserver-users] ms7 How to use FILTER
    Steve.Toutant at inspq.qc.ca
    Thu Mar 26 07:27:01 PDT 2015
Thanks Steve, yes it helps!
If an SQL query is needed, would you suggest to do it in the DATA
statement as a subquery or use PROCESSING ?native_filter=native SQL
string?
steve
"Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us>
2015-03-26 10:20
A
"Steve.Toutant at inspq.qc.ca" <Steve.Toutant at inspq.qc.ca>,
"mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
cc
Objet
RE: [mapserver-users] ms7 How to use FILTER
MapServer FILTERs are now only written using MapServer expression syntax
(e.g. (?[someitem]? != ?someval?)). Drivers can support translation
capabilities to create native SQL under the hood. This was done to
standardize the syntax across all drivers. Prior to 7.0 the syntax varied
by driver. In addition, FILTER values are preserved when used with WFS or
native MapServer attribute queries.
With database backends there has been little reason to use FILTERs since
you could often just extend the DATA statement.
Note that if need to you can still define a native SQL independently of
the DATA statement using the processing tag ?native_filter?, for example:
  PROCESSING ?native_filter=native SQL string?
This is also preserved with WFS. Does this help?
Steve
mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
Sent: Thursday, March 26, 2015 8:20 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] ms7 How to use FILTER
I'm confused on how to use FILTER when datasource is postgis or Oracle
Spatial (Native Connection)
In an old thread, I was told to not use FILTER, but use a WHERE clause in
the Data statement.
In the ms7 Mapfile-Layer-Data doc, I see for Oracle
"Note that there are important performance impacts when using spatial
subqueries however. Try using MapServer?s FILTER whenever possible
instead."
I remember I had a bug with MS6 when using FILTER using WFS. A getfeature
on the layer with a spatial or logical filter, the FILTEr in the mapfile
was overwritten.
Please, how should we define/use FILTER int a mapfile with postgis and
also oracle (using native connection, not ogr)?
THANKS!
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150326/38cf428b/attachment.htm>
More information about the MapServer-users
