[mapserver-users] [EXTERNAL] Re: Mapserver 7+oracle - wfs getFeature with filter on numeric field
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Thu May 14 06:43:11 PDT 2015
The matchCase triggers a string comparison. matchCase doesn't seem to make sense for a number.
That being said, I can look into the specific case of matchCase and a numeric comparison and make sire that it isn't used.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
michael.smith at usace.army.mil
From: "Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>" <Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>>
Date: Thursday, May 14, 2015 at 9:28 AM
To: Michael Smith <michael.smith at erdc.dren.mil<mailto:michael.smith at erdc.dren.mil>>
Cc: MapserverList OSGEO <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>, thomas bonfort <thomas.bonfort at gmail.com<mailto:thomas.bonfort at gmail.com>>
Subject: Re: [EXTERNAL] Re: [mapserver-users] Mapserver 7+oracle - wfs getFeature with filter on numeric field
Is there a documentation that says that it is not?
Folks from gdal list also think that it is not supported...I guess you are right. But as I said on the gdal list, many countries are using a comma as a decimal separator....what other people on the planet do?
Anyway the comma is another problem that I try to manage later......
For now, We have an application that generate and launch spatial queries on WFS, matchCase=false by default. Before modifying the code I want to understand what is going on....
It seems,when using numeric value, that matchCase as no impact in PostGIS, but it is important in oracle to be set to true
gml_type = auto, returns double in postgis and oracle, so that is fine
A WFS getFeature with the operator PropertyIsEqualTo AND matchCase=false
using this value -64.225
PostGis: it works
Oracle (from mike's test): it fails...matchCase must be set to true
using this value -64,225
PotsGis: not tested
Oracle: it fails...matchCase must be set to true
Is there a reason why, with oracle, matchCase should be set to true when using numeric value, or that could be fixed?
Regards
Steve
"Smith, Michael ERDC-RDE-CRREL-NH" <Michael.Smith at erdc.dren.mil<mailto:Michael.Smith at erdc.dren.mil>>
2015-05-14 09:17
A
cc
Objet
Its not clear to me that commas as the decimal separator is supported in XML/GML. I can't find any documentation to indicate that it is. Can you point some out to me?
In any event, I didn't test with comma decimal separators.
Mike
Michael Smith
US Army Corps
michael.smith at usace.army.mil<mailto:michael.smith at usace.army.mil>
Date: Thursday, May 14, 2015 at 8:54 AM
Thanks Mike for having a look at it.
Your decimals are separated by a comma or a dot?
2015-05-13 18:53
A
"Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>" <Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>>, thomas bonfort <thomas.bonfort at gmail.com<mailto:thomas.bonfort at gmail.com>>
cc
Objet
Steve,
I tested this out with 7.1 with numeric type fields and it works for me as long as I don't use matchCase="false". That seems to kick it in to a string comparison. matchCase="true" and just PropertyIsEqualTo work fine.
In our metadata we use "gml_types" "auto" when the database knows the types and explicit declarations (eg "gml_attributename_type" "integer") when it doesn't work.
The key is that the field type has to report as a numeric type or the backend treats it as a string comparison.
Mike
Michael Smith
US Army Corps
Date: Wednesday, May 13, 2015 at 10:35 AM
To: thomas bonfort <thomas.bonfort at gmail.com<mailto:thomas.bonfort at gmail.com>>
Subject: [EXTERNAL] Re: [mapserver-users] Mapserver 7+oracle - wfs getFeature with filter on numeric field
Resent-From: Michael Smith <michael.smith at usace.army.mil<mailto:michael.smith at usace.army.mil>>
Precision: we are using MS7.1
Removing matchcase part makes oracle, and postgis, crash.
I have this error:
<ows:ExceptionReport xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance<http://www.google.com/url?q=http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance&sa=D&sntz=1&usg=AFQjCNFERp6A_kcvqihMCKJ7EHX8O14vIA>" xmlns:ows="http://www.opengis.net/ows<http://www.google.com/url?q=http%3A%2F%2Fwww.opengis.net%2Fows&sa=D&sntz=1&usg=AFQjCNE9_q7eSkcBl4XJimXTw1Zx0EiDow>" version="1.1.0" language="en-US"xsi:schemaLocation="http://www.opengis.net/ows< /a><http://www.google.com/url?q=http%3A%2F%2Fwww.opengis.net%2Fows&sa=D&sntz=1&usg=AFQjCNE9_q7eSkcBl4XJimXTw1Zx0EiDow>http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd<http://www.google.com/url?q=http%3A%2F%2Fschemas.opengis.net%2Fows%2F1.0.0%2FowsExceptionReport.xsd&sa=D&sntz=1&usg=AFQjCNGmnK6iSrh-cSWEtM2VV17uuSbVNA>">
<ows:Exception exceptionCode="NoApplicableCode" locator="mapserv">
<ows:ExceptionText>
msWFSGetFeature(): WFS server error. FLTApplyFilterToLayer() failed msOracleSpatialLayerWhichShapes(): OracleSpatial error. Check your data statement and server logs
</ows:ExceptionText>
The problem might be the decimals?
Here is the request
<wfs:Query typeName="feature:SMDVDP_STAT_METE" srsName="EPSG:32198">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>LONG_STAT</ogc:PropertyName>
<ogc:Literal>-61,8031</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
2015-05-13 05:40
A
cc
Objet
can you try the same request without the "matchCase" part and report
back please?
On 12 May 2015 at 18:11, <Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>> wrote:
> I have a problem using a FILTER in a wfs getFeature request on an oracle DB
> with MS7
> When I launch a getFeature request with a Filter on a numeric field it
> doesn't work,
> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyIsEqualTo
> matchCase="false"><ogc:PropertyName>LONG_STAT</ogc:PropertyName><ogc:Literal>-61</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
> here is the error we get in the browser
> <ows:ExceptionText>msWFSGetFeature(): WFS server error.
> statement and server logs</ows:ExceptionText>
> from mapserver logs
> [Tue May 12 11:59:10 2015].177992 msOracleSpatialLayerTranslateFilter.
> String: ([LONG_STAT] =*-61)
> LONG_STAT is a NUMBER in the DB
> DescribefeatureType returns
> <element name="NO_STAT_CLIM" minOccurs="0" type="string"/>
> <element name="NO_STAT_FADQ" minOccurs="0" type="string"/>
> <element name="NOM_STAT" minOccurs="0" type="string"/>
> <element name="LATI_STAT" minOccurs="0" type="string"/>
> <element name="LONG_STAT" minOccurs="0" type="string"/>
> <element name="ALTI_STAT" minOccurs="0" type="string"/>
> I tried to add "gml_types" "auto" in the mapfile, but it still returns
> string as data type
> I tried "gml_LONG_STAT_type" = "Integer" in the mapfile, describeFeatureType
> returns "<element name="LONG_STAT" minOccurs="0" type="double"/> " but I
> still get an error in getFeature
> I'm using CONNECTIONTYPE oraclespatial in the mapfile
> I can provide more information....
> Is it a known issue or can I do something about that?
> Thank you!
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150514/d3cb2a87/attachment-0001.html>
