[mapserver-users] [EXTERNAL] Re: Mapserver 7+oracle - wfs getFeature with filter on numeric field
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue May 19 14:08:58 PDT 2015
Without being a programmer I would like to see what would happen if this source file
https://github.com/mapserver/mapserver/blob/branch-7-0/maporaclespatial.c
would be edited around line 571-573:
cmd = "alter session set NLS_DATE_FORMAT='yyyy-mm-dd hh24:mi:ss'";
by adding a new block for setting the decimal and thousands separators for output
cmd = "alter session set NLS_NUMERIC_CHARACTERS='. '";
I am not sure of the right syntax. This one works with SQL*Plus and set decimal points and space for thousands separator. I think that thousands should be without separators but the command seems to require two inputs.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Lime, Steve D (MNIT)
Lähetetty: 19. toukokuuta 2015 22:12
Vastaanottaja: Steve.Toutant at inspq.qc.ca; MapserverList OSGEO
Kopio: Michael.Smith at erdc.dren.mi
Aihe: Re: [mapserver-users] [EXTERNAL] Re: Mapserver 7+oracle - wfs getFeature with filter on numeric field
Is there somewhere in the capabilities response where a user would declare what decimal separators are supported?
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>
Sent: Tuesday, May 19, 2015 2:06 PM
To: MapserverList OSGEO
Cc: Michael.Smith at erdc.dren.mi<mailto:Michael.Smith at erdc.dren.mi>
Subject: Re: [mapserver-users] [EXTERNAL] Re: Mapserver 7+oracle - wfs getFeature with filter on numeric field
It seems to be a bug isn't?
Do you want me to open an issue?
"Smith, Michael ERDC-RDE-CRREL-NH" <Michael.Smith at erdc.dren.mil<mailto:Michael.Smith at erdc.dren.mil>>
2015-05-19 12:24
A
"Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>" <Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>>
cc
"Rahkonen Jukka (MML)" <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>, MapserverList OSGEO <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Objet
It looks like whats happening is that's being converted into 3 Tokens and the oracle driver converts it into a number + comma + number.
The tokenizer is not treating that value as a single value.
Mike
From: "Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>" <Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca>>
Date: Tuesday, May 19, 2015 at 11:44 AM
To: Michael Smith <michael.smith at erdc.dren.mil<mailto:michael.smith at erdc.dren.mil>>
Cc: "Rahkonen Jukka (MML)" <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>, MapserverList OSGEO <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
here is the mapserver log with <ogc:PropertyIsEqualTo matchCase="true"><ogc:PropertyName>LONG_STAT</ogc:PropertyName><ogc:Literal>-61,8031</ogc:Literal></ogc:PropertyIsEqualTo>
msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data: SELECT ID, NO_STAT_CLIM, NO_STAT_FADQ, NOM_STAT, LATI_STAT, LONG_STAT, ALTI_STAT, D_DEB, D_FIN, TIMB_MAJ, USAG_MAJ, rownum, GEOM_POIN FROM (select * FROM SMDVDP_STAT_METE WHERE EXTRACT(YEAR FROM D_DEB) = 2014) WHERE ( LONG_STAT = -61.000000,8031.000000 ) AND SDO_FILTER( GEOM_POIN, MDSYS.SDO_GEOMETRY(2003, :srid, NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates ),'querytype=window') = 'TRUE'
The problem is
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150519/c67282b4/attachment-0001.html>
