[mapserver-users] Issue adding mapcache into AutoCAD Civil 3D via WMS
Mark Volz
MarkVolz at co.lyon.mn.us
Fri May 29 07:52:36 PDT 2015
Hello,
I am having trouble loading the MapCache WMS layers into AutoCAD Civil 3D. I set the projection to my county coordinates, which is what MapCache uses. Next I loaded the MapCache WMS server. Unfortunately I got an error:
There was a problem adding data to Map.
Failed to get bands data.
The HTTP request could not be understood by the server due to malformed syntax.
I was able to load other WMS layers in AutoCAD.
In ArcMap, I initially received an error that there is no <grid> with suitable srs found for the layer. This issue was quickly resolved when I changed the coordinate system to county coordinates?
Questions:
If possible, What needs to be done so that I can load mapcache layers into AutoCAD Civil 3D? Do I just need to break down and cache the WGS 84 grid?
Thank You
Sincerely,
Mark Volz
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150529/1a053b11/attachment.html>
