[mapserver-users] wms error in arcgis 10.3
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 9 01:52:58 PST 2015
GetCapabilities seem so announce <CRS>EPSG:102067</CRS> as one of the supported projections but based on the error message Mapserver has troubles with it:
Description: " Service Error Description: init=epsg:102067 Service Error Description: " Service Error Description: msProcessProjection():
Have you added EPSG:102067 manually into your EPSG file and have you checked that it works with some other client?
-Jukka Rahkonen-
Martin Landa wrote:
Hi all,
my colleagues who are using ArcGIS have strange problem with WMS service [1]. The problem appears only in ArcGIS 10.3 (interstigly not in 10.2.1) when you add shapefile in EPSG:5514 and then map layer from this WMS server. If you add WMS layer to empty project, it works.
The error message:
One or more layers failed to draw: Rain WMS server: WMS service exceptions:Service Error Description: msProcessProjection():
Projection library error. proj error Service Error Description: "
Service Error Description: no options found in Service Error
Description: ' Service Error Description: init Service Error
Description: ' Service Error Description: file Service Error
Description: " Service Error Description: for Service Error
Do you have any idea what could be wrong? Thanks in advance, Martin
[1] http://rain1.fsv.cvut.cz/services/wms?service=wms&request=GetCapabilities&version=1.3.0
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
