[mapserver-users] WMS Layer provided by MapSever rendering incorrectly in ol3.
Michael Smith
michael.smith.erdc at gmail.com
Tue Nov 17 03:36:36 PST 2015
Neelesh,
You need to set your map projection to match your basemap. You need to set
it to spherical mercator.
PROJECTION
"init=epsg:3857"
END
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
michael.smith at usace.army.mil
From: mapserver-users <mapserver-users-bounces at lists.osgeo.org> on behalf
of Neelesh Nirmal <neelesh.iiita at gmail.com>
Date: Tuesday, November 17, 2015 at 5:37 AM
To: <mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] WMS Layer provided by MapSever rendering
incorrectly in ol3.
> I have created a map using OpenLayers3 which contains two layers. First layer
> is Open Street Map Layer and the second one is WMS layer provided by the Map
> Server.
> Problem-When i'm rendering first layer it is rendering properly no issue. but
> when i'm rendering the second layer(provide by map server) it renders
> incorrectly means it does not fit to its container and it is out of sync with
> the first layer in terms of location. See this snapshot
> <http://i.stack.imgur.com/Ac8xR.png> of the maps for more clarification. In
> the snapshot top layer is wms layer provided by map server.
> Also when i'm zooming or moving the map then both layers work correctly but
> after a delay of few seconds the second layer(wms layer from map server) again
> switches back to its initial position(Position that is shown in above attached
> snapshot).
> This is the code that i'm using to consume wms service.
> var layer = new ol.layer.Image({
> source: new ol.source.ImageWMS({
> url: 'http://localhost:19090/rasters/world/wms',
> params: {
> 'LAYERS': 'world',
> 'mode': 'map',
> serverType: 'mapserver'
> This <http://pastebin.com/AWWWyBLE> is my map file.
> MAP
> NAME "world"
> CONFIG "MS_ERRORFILE"
> "/home/neelesh/Projects/georbis/data/logs/mapservice_errors.log"
> CONFIG "PROJ_LIB"
> "/home/neelesh/Projects/georbis/deps/proj.4-master/share/proj"
> CONFIG "ON_MISSING_DATA" "LOG"
> DEBUG 5
> EXTENT -180.000 -90.000 180.000 90.000
> SHAPEPATH "/home/neelesh/Projects/georbis/data/service_data/data/wms"
> IMAGECOLOR 255 255 255
> SIZE 1350 675
> WEB
> METADATA
> "wms_title" "Georbis WMS Server"
> "wms_author" "VizExperts"
> "wms_onlineresource" "http://192.168.1.36:19090/rasters/world/wms?"
> "wms_enable_request" "*"
> "wms_srs" "epsg:4326"
> "wms_feature_info_mime_type" "text/html"
> "wms_format" "image/jpg"
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME world
> TYPE RASTER
> DATA "world.tif"
> METADATA
> "wms_title" "BlueWorld Map"
> "wms_server_version" "1.1.1"
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> END
> I tried ol.view.fit method to fit the layer to its container but the value of
> layer.getExtent() for the layer is undefined.
> Also layers are rendering perfectly in QGIS and when i'm using the same layer
> from geoserver instead of mapserver again it is working fine.
> This
> <http://stackoverflow.com/questions/33539777/wms-layer-provide-by-map-sever-re
> ndering-incorrectly-in-ol3> is link to my stackoverflow post.
> Pleas help me to find out what is wrong. is there any problem with wms request
> format or the map file?
> _______________________________________________ mapserver-users mailing list
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151117/2e729ca2/attachment-0001.html>
