[mapserver-users] WMS Layer provided by MapSever rendering incorrectly in ol3.
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue Nov 17 05:49:36 PST 2015
Don’t use mode=map because you want to read Mapserver as WMS. Make just a plain WMS layer like in view-source:http://dev.openlayers.org/examples/wms.html.
-Jukka Rahkonen-
Neelesh Nirmal wrote:
I have created a map using OpenLayers3 which contains two layers. First layer is Open Street Map Layer and the second one is WMS layer provided by the Map Server.
Problem-When i'm rendering first layer it is rendering properly no issue. but when i'm rendering the second layer(provide by map server) it renders incorrectly means it does not fit to its container and it is out of sync with the first layer in terms of location. See this snapshot<http://i.stack.imgur.com/Ac8xR.png> of the maps for more clarification. In the snapshot top layer is wms layer provided by map server.
[Lähettäjä poisti kuvan.]<http://i.stack.imgur.com/Ac8xR.png>
Also when i'm zooming or moving the map then both layers work correctly but after a delay of few seconds the second layer(wms layer from map server) again switches back to its initial position(Position that is shown in above attached snapshot).
This is the code that i'm using to consume wms service.
var layer = new ol.layer.Image({
source: new ol.source.ImageWMS({
url: 'http://localhost:19090/rasters/world/wms',
params: {
'LAYERS': 'world',
'mode': 'map',
serverType: 'mapserver'
This<http://pastebin.com/AWWWyBLE> is my map file.
MAP
NAME "world"
CONFIG "MS_ERRORFILE" "/home/neelesh/Projects/georbis/data/logs/mapservice_errors.log"
CONFIG "PROJ_LIB" "/home/neelesh/Projects/georbis/deps/proj.4-master/share/proj"
CONFIG "ON_MISSING_DATA" "LOG"
DEBUG 5
EXTENT -180.000 -90.000 180.000 90.000
SHAPEPATH "/home/neelesh/Projects/georbis/data/service_data/data/wms"
IMAGECOLOR 255 255 255
SIZE 1350 675
WEB
METADATA
"wms_title" "Georbis WMS Server"
"wms_author" "VizExperts"
"wms_onlineresource" "http://192.168.1.36:19090/rasters/world/wms?"
"wms_enable_request" "*"
"wms_srs" "epsg:4326"
"wms_feature_info_mime_type" "text/html"
"wms_format" "image/jpg"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME world
TYPE RASTER
DATA "world.tif"
METADATA
"wms_title" "BlueWorld Map"
"wms_server_version" "1.1.1"
END
PROJECTION
"init=epsg:4326"
END
END
END
I tried ol.view.fit method to fit the layer to its container but the value of layer.getExtent() for the layer is undefined.
Also layers are rendering perfectly in QGIS and when i'm using the same layer from geoserver instead of mapserver again it is working fine.
This<http://stackoverflow.com/questions/33539777/wms-layer-provide-by-map-sever-rendering-incorrectly-in-ol3> is link to my stackoverflow post.
Pleas help me to find out what is wrong. is there any problem with wms request format or the map file?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151117/7f7f55f0/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151117/7f7f55f0/attachment-0001.jpg>
