[mapserver-users] Shapefile spatial index challenge
Ben Madin
ben at ausvet.com.au
Thu Oct 22 23:22:59 PDT 2015
G’day Lydon,
I feel your pain, but there is little benefit to creating more quadrants. The idea (as I understand it - could be wrong) is to be able to use a (fast) bounding box to find the polygons to test, rather than having to test against every polygon using more complex algorithms.
I suppose you could consider that if you want to find out if a point is in one or more of your polygons, the benefit of having more index squares. You only have 8 polygons (I presume) so this should limit you in most cases to only having to compare your ‘point’ with only a couple of polygons using the more complex algorithms.
hth
cheers
Ben
> On 2015-10-08, at 21:31 , Lydon Chandra <lydon_chandra at technologyonecorp.com> wrote:
> Hi List,
> How can we generate more quadrants for the spatial index for the Australia polygon below ?
> Using MapServer shptree, even forcing it to go to 50 level deep, the spatial index does not have more quadrants.
> More data and details at:
> http://www.evernote.com/l/AhrYASBGtqVOkJn0BLqZkceADvOsA_UBfvY/ <http://www.evernote.com/l/AhrYASBGtqVOkJn0BLqZkceADvOsA_UBfvY/>
> <image.png>
> Kind Regards,
> Don
> mapserver-users at lists.osgeo.org
Ben Madin
t : +61 8 6102 5535
m : +61 448 887 220
e : ben at ausvet.com.au
AusVet Animal Health Services
18/27 Market Street, Fremantle
Western Australia
AusVet's website: http://www.ausvet.com.au Find our office: http://w3w.co/leader.code.frozen
This transmission is for the intended addressee only and is confidential information. If you have received this transmission in error, please delete it and notify the sender. The contents of this email are the opinion of the writer only and are not endorsed by AusVet Animal Health Services unless expressly stated otherwise. Although AusVet uses virus scanning software we do not accept liability for viruses or similar in any attachments. Thanks for reading. The average disclaimer at the bottom of an email is probably never read but contributes substantially to increasing the size of packet being sent through the internet and ultimately congestion.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151023/94ce8a2b/attachment.html>
