[mapserver-users] No Layers when configuring TinyOWS with a Mapserver (.map) File
Richard Greenwood
richard.greenwood at gmail.com
Tue Oct 27 06:09:46 PDT 2015
I am also unable to get tinyows to work using a map file, even with the
example map file from the documentation. I have both the example and my own
layer working with an XML file, so I believe there is either a bug with map
file support or something missing from the documentation.
Regardless of whether I have a valid or invalid map file tinyows always
returns:
<Exception exceptionCode='LayerNotDefined' locator='typename'>
<ExceptionText>Unknown layer name</ExceptionText>
</Exception>
I've tested with both an OpenLayers web interface and with QGIS. I built
1.1.1 from source on Ubuntu 14.04.
Can anyone suggests steps that I should take to narrow down the problem
more?
Thanks,
Rich
On Mon, Oct 12, 2015 at 4:26 AM, Balajee R.C <balajee at vizexperts.com> wrote:
> Am trying to expose a vector layer (loaded from shape file into PostGIS)
> as a WFS layer using tinyows.
> Following the instructions in the mapserver/tinyows documentation, here is
> the .map file I have come up with so far:
> MAP
> NAME "world"
> CONFIG "MS_ERRORFILE"
> "/home/balajeerc/Projects/Build_Dir/myproject/data/logs/mapservice_errors.log"
> EXTENT -180.000 -90.000 180.000 90.000
> WEB
> METADATA
> "tinyows_schema_dir"
> "/home/balajeerc/Projects/Build_Dir/myproject/deps/mygis-services-0.1/data/schema"
> "tinyows_onlineresource" "
> http://192.168.43.164:19090/vectors/world/wfs?"
> "wfs_title" "MyGIS Feature Service: World"
> "wfs_contact" "support at giscompany.com"
> "wms_title" "MyGIS Feature Service: World"
> "wms_srs" "epsg:4326"
> "wms_enable_request" "*"
> "log_level" "15"
> "log"
> "/home/balajeerc/Projects/Build_Dir/myproject/deps/mygis-services-0.1/data/logs/wfs_world.log"
> "ows_contactorganization" "MyCompany"
> "ows_contactelectronicmailaddress" "contact at giscompany.com
> "ows_contactperson" "Balajee.R.C"
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME 'world_boundaries'
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost user=mygis password=asdf123
> dbname=mygis port=19095"
> DATA "geom from world_boundaries"
> TYPE POLYGON
> METADATA
> 'wfs_title' 'world_boundaries'
> 'wfs_namespace_prefix' 'tows'
> 'wfs_namespace_uri' 'http://www.giscompany.com/'
> 'wfs_srs' 'epsg:4326'
> 'wms_srs' 'epsg:4326'
> 'wms_title' 'world_boundaries'
> 'tinyows_table' 'world_boundaries'
> 'tinyows_writable' '1'
> 'tinyows_retrievable' '1'
> END
> CLASS
> STYLE
> COLOR 128 128 128
> ANTIALIAS true
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> DUMP TRUE
> END
> END
> This .map file works fine with mapserver, i.e. I am able to render the
> feature layer as a WMS service using QGIS as a client.
> However, the WFS service (served by tinyows) using the same file (set
> using `TINYOWS_MAPFILE` environment variable seems to show no layers in
> GetCapabilities (and hence QGIS is not able to load any).
> The output from `tinyows --check` is as follows:
> balajeerc at Balajee:~/Projects/tinyows-1.1.1$ ./tinyows --check
> TinyOWS version: 1.1.0
> FCGI support: Yes
> Config File Path:
> /home/balajeerc/Projects/Build_Dir/myproject/data/service_data/data/wfs/world.map
> (Mapfile)
> PostGIS Version: 2.1.8
> PostGIS dsn: host=localhost user=mygis password=asdf123
> Output Encoding: UTF-8
> Database Encoding: UTF8
> Schema dir:
> Display bbox: Yes
> Estimated extent: No
> Check schema: Yes
> Check valid geoms: Yes
> Available layers:
> Note that even though I am using a 1.1.1 version of tinyows, it prints
> tinyows version as 1.1.0. Also note that it prints no layers.
> Wondering what is going wrong, I decided to step into the code. I
> recompiled code after turning off (`-O2`) optimizations and with debugging
> (`-g`) enabled.
> I am only able to get so far as the `ows_parse_config` method in
> `src/ows/ows_config.c`. I am, for some reason not able to step into
> `ows_parse_config_map` in `src/mapfile/mapfile.c`. This probably has
> something to do with the fact that `mapfile.c` is generated by flex using
> `src/map/mapfile.l`.
> At this point I am completely stuck and at a brick wall as to what might
> be going wrong. Can someone here please help?
> TinyOWS version: 1.1.1 (Release
> <https://github.com/mapserver/tinyows/releases/tag/v.1.1.1>)
> Regards,
> Balajee.R.C
> mapserver-users at lists.osgeo.org
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151027/dadaebb9/attachment-0001.html>
