[mapserver-users] DATA "table" does not find FID for WFS
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Oct 28 04:12:55 PDT 2015
I am testing with MS4W 3.1.0 and the GDAL that is included seems to be
C:\ms4w>gdalinfo --version
GDAL 2.0.0, released 2015/06/14
I believe that it should include #5781
-Jukka-
Even Rouault wrote:
Le mercredi 28 octobre 2015 08:10:44, Rahkonen Jukka (MML) a écrit :
> Hi,
> I have noticed with Mapserver 7.0 that WFS server does not find the
> "gml_featureid" column if I define DATA this way:
> CONNECTIONTYPE OGR
> CONNECTION "\ms4w\apps\wms-wfs.sqlite"
> DATA "states"
> This gives a warning into GML sent by GetFeature
> <!-- WARNING: FeatureId item 'PK_UID' not found in typename 'states_table'.
> and featureMembers are without fid
> <gml:featureMember>
> <ms:states_table>
> This leads to correct result:
> CONNECTIONTYPE OGR
> DATA "select * from states"
> <gml:featureMember>
> <ms:states_table fid="states_table.1">
> Documentation http://www.mapserver.org/input/vector/ogr.html does not
> warn that defining data as "layer_name" vs. "select * from layer"
> could make a difference. Ogrinfo finds the FID column and reports it
> as: FID Column = PK_UID
> PK_UID is defined in the table as
> CREATE TABLE states (
> PK_UID INTEGER PRIMARY KEY AUTOINCREMENT,
> This looks like a bug but I am not sure if it is a Mapserver bug of
> GDAL bug and if it affects only Spatialite.
You didn't specify which GDAL version is used.
That could possibly be the following bug that was fixed in 1.11.2 and 2.0:
* make GetFIDColumn() work when run as first method call (#5781)
> -Jukka Rahkonen-
Spatialys - Geospatial professional services http://www.spatialys.com
