[mapserver-users] DATA "table" does not find FID for WFS
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Oct 28 05:24:28 PDT 2015
> The GML output tries to find a item/field with the name of the gml_featureid.
> But the FID column in OGR is treated specially and not reported as a regular field.
I guess that it means that the issue does not affect only Spatialite, and the resolution would be to make GML output to try if it finds the "gml_featureid" field from the regular fields _OR_ from the field that is reported by OGR as "FID Column".
The latter could be tried also if "gml_featureid" is missing from the mapfile or if it was set to " gml_featureid" "AUTO". I am not sure if this is a good idea or not because the native vector drivers should be adapted as well.
Should I file a Mapserver issue into Github about FID Columns getting hidden?
-Jukka-
Even Rouault wrote:
Le mercredi 28 octobre 2015 12:12:55, Rahkonen Jukka (MML) a écrit :
> Hi,
> I am testing with MS4W 3.1.0 and the GDAL that is included seems to be
> C:\ms4w>gdalinfo --version
> GDAL 2.0.0, released 2015/06/14
> I believe that it should include #5781
Yes, but that is irrelevant to your issue when looking closer.
But the FID column in OGR is treated specially and not reported as a regular field. Which explains the error. In the case of "select * from table_name" as pk_uid is different from ogc_fid then it is just recognized as a regular column, which makes things work. So even "select * from table_name" isn't a guarantee that things are going to work. If the primary key field was named ogc_fid, you'd have to do "select ogc_fid as pk_uid, * from table_name" so it appears as a regular OGR field.
> -Jukka-
> Even Rouault wrote:
> Le mercredi 28 octobre 2015 08:10:44, Rahkonen Jukka (MML) a écrit :
> > Hi,
> > I have noticed with Mapserver 7.0 that WFS server does not find the
> > "gml_featureid" column if I define DATA this way:
> > CONNECTIONTYPE OGR
> > CONNECTION "\ms4w\apps\wms-wfs.sqlite"
> > DATA "states"
> > This gives a warning into GML sent by GetFeature
> > <!-- WARNING: FeatureId item 'PK_UID' not found in typename
> > 'states_table'. --> and featureMembers are without fid
> > <gml:featureMember> <ms:states_table>
> > This leads to correct result:
> > CONNECTIONTYPE OGR
> > DATA "select * from states"
> > <gml:featureMember>
> > <ms:states_table fid="states_table.1">
> > Documentation http://www.mapserver.org/input/vector/ogr.html does
> > not warn that defining data as "layer_name" vs. "select * from layer"
> > could make a difference. Ogrinfo finds the FID column and reports it
> > as: FID Column = PK_UID
> > PK_UID is defined in the table as
> > CREATE TABLE states (
> > PK_UID INTEGER PRIMARY KEY AUTOINCREMENT,
> > This looks like a bug but I am not sure if it is a Mapserver bug of
> > GDAL bug and if it affects only Spatialite.
> You didn't specify which GDAL version is used.
> That could possibly be the following bug that was fixed in 1.11.2 and 2.0:
> * make GetFIDColumn() work when run as first method call (#5781)
> > -Jukka Rahkonen-
> Spatialys - Geospatial professional services http://www.spatialys.com
