[mapserver-users] CSV from Mapscript results
Michael Smith
michael.smith.erdc at gmail.com
Tue Sep 8 18:18:37 PDT 2015
Another option would be to use the csv ogr driver and set the outputformat
http://mapserver.org/output/ogr_output.html
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
michael.smith at usace.army.mil
-----Original Message-----
From: <mapserver-users-bounces at lists.osgeo.org> on behalf of Matej Mailing
<mailing at tam.si>
Date: Tuesday, September 8, 2015 at 8:03 PM
To: "Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us>
Cc: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] CSV from Mapscript results
>Thanks, Steve.
>It looks I will choose the 2nd option as well. What I don't like with
>this "direct" approach though is not using already existing Mapfile
>with DATA, CONNECTION and everything set - basically it creates
>another point where this data needs to be set and changed for example
>when changing access rights, moving data to new server etc., it
>increases complexity.
>As far as I have checked, there is no for example getData() method to
>get the DATA variable, set in the Mapfile. (Perhaps the reason is that
>since there is no set, there is no get method as well :-))
>However, in this case this would be useful or perhaps I am just
>thinking in the wrong direction? :-)
>Thanks,
>Matej
>2015-09-08 18:07 GMT+02:00 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>:
>> You have two options:
>> 1 - use query templates to render the result as CSV
>> 2 - use whatever tool your programming language gives you and just
>>loop through the results and dump to CSV
>> Personally since you're using MapScript I'd opt for 2 for a couple of
>>reasons: you have total control that way and for larger result sets it's
>>likely to be more performant since the whole CSV file wouldn't need to
>>be constructed in memory like templates would.
>> Steve
>> From: mapserver-users-bounces at lists.osgeo.org
>>[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Matej
>>Mailing
>> Sent: Tuesday, September 08, 2015 5:30 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] CSV from Mapscript results
>> Hi,
>> what would be the best way to create a CSV from Mapscript query results?
>> Thanks,
>> Matej
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
