[mapserver-users] rendering a raster crossing the antimeridian through a WMS
fred p
mapoubelle22 at gmail.com
Wed Sep 9 06:03:26 PDT 2015
Thanks for your answer.
I just have uploaded again the files, it should be OK now.
I am using mapserver-6.4.1 and gdal-1.11.2.
2015-08-27 21:53 GMT+02:00 TC Haddad <tchaddad at gmail.com>:
> Hello Fred
> For some reason I cannot see or download your "expected" image (some sort
> of file error?), so perhaps you can re-post it.
> I recently worked through a very similar problem and was successful by
> using a VRT to provide the necessary offset. If your issue is the same, I
> can provide example solution that worked for me...
> can you say what version of Mapserver and GDAL you are using?
> Tanya
> On Thu, Aug 27, 2015 at 7:21 AM, fred p <mapoubelle22 at gmail.com> wrote:
>> Hello,
>> I still cannot get the full image, using shp2img or mapserv commands.
>> I have uploaded the mapfile, the original image, the result image and the
>> expected image (got from gdalwarp) here :
>> ftp://ftp.meteo.fr/pub/CMS/mapserver/
>> Does someone has got an idea on how to work around it ?
>> Thanks !
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150909/885619e8/attachment.html>
