[mapserver-users] Render PostGIS points as raster layer
Adam Ryan
adamdryan at gmail.com
Tue Sep 15 16:36:29 PDT 2015
I have over 100 million rows in a PG table with geom type Point,
srid=4326. The points represent timestamped centroids of raster cells.
The data comes from sparse hourly 1km US grids; Only the cells with data,
which is less than 1%, but still a lot of points. The PG table allows for
a wealth of spatial-temporal queries, but I want to render as a raster
because it is raster data after all. Currently I use ST_Expand to
approximate a grid cell as a polygon:
LAYER
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION [host, port, etc...]
DATA "geom FROM (SELECT id, ST_Expand( geom, 0.005 ) as geom from
[query]) as foo using unique id using srid=4326"
This works, sorta. In my classifications I set the style COLOR and
OUTLINECOLOR the same, but the overlapping 'cell' outlines never look as
good as output from a raster.
So I want to use a mapserver layer type RASTER. I can create a raster in
PG by using ST_AsRaster, but I can't see how to pass it to mapserver:
LAYER
TYPE RASTER
DATA "PG:host=[host] port=5432 dbname=[dbname] where=' where?
The DATA (connection string) here takes a table name and a where but I
really need it to take an SQL string that returns the correct type.
Is there a way to do this? Would a GDAL virtual raster be able to
accomplish this? I've never worked with them.
Thanks for the all the progress over the years,
Adam
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150915/ff5338fd/attachment.html>
