[mapserver-users] html tags in GetFeatureInfo
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Sep 18 03:01:49 PDT 2015
I noticed that Sören just solved the problem but because my mail was ready I send it anyway.
We have html-formatted strings in the database and we show them through GetFeatureInfo (text/html) like this:
LAYER includes "wms_feature_info_mime_type" "text/html" in the metadata and template is given in the CLASS
CLASS
NAME "kalastuskielto"
template "kalastuskielto.html"
The template "kalastuskielto.html" is like this:
<!-- MapServer Template -->
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=UTF-8"></meta>
<title>Kalastuskieltoalue</title>
</head>
<body>
<h3>NIMI</h3>
[item name=NIMI format="$value" escape=none]
<h3>LISÄTIEDOT</h3>
[item name=KIELLONLISATIETO format="$value" escape=none]
<h3>VOIMASSAOLO</h3>
[item name=VOIMASSAOLO format="$value" escape=none]
<h3>YHTEYSTIEDOT</h3>
[item name=YHTEYSTIEDOT format="$value" escape=none]
</body>
</html>
You can test the result from
http://www.paikkatietoikkuna.fi/web/fi/kartta?ver=1.17&zoomLevel=9&coord=400299_6944922&mapLayers=base_35+100+default,1373+100+&&showMarker=true
Click on the red coloured river.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Jörg Thomsen wrote:
> Hello Sören,
> I guess the html-tags are escaped by mapserver, try to use the raw-output:
> [attribute name],[attrribute name_esc],[attribute item name_raw] ...
> By default the attributes are encoded
> especially for HTML representation. In addition the escaped version
>(for use in URLs) as well as the raw data is available.
http://mapserver.org/mapfile/template.html
Jörg
Am 18.09.2015 um 11:13 schrieb Horn, Sören:
> Hi,
> I'm using the GetFeatureInfo to show some column values from a
> database.
> Everything works just fine.
> But now I want to use html tags, such as <strong>, <em> and <br> for
> styling my output text.
> So I tried to write my content with the html syntax, like
> "<strong>some-strong-content</strong><br>normal-text<em>some-emphasize
> d-text</em>",
in a PostGIS column description (with datatype 'text').
> Code snippet from my Getfeatureinfo html:
> <tr>
> <td>Content</td>
> <td>[description]</td>
> </tr>
> But the GetFeatureInfo do not interpret the html tags and write the
> exact column value (with all html tag).
> Is there a possibility to use html tags in a PostGIS database that are
> interpreted by MapServers GetFeatureInfo?
> OS: Debian GNU/Linux 7.8 (wheezy)
> kernel: 3.2.0-4-amd64
> MapServer: 6.4
> PostGIS: 1.5
> Best regards,
> Sören Horn
> __________________
> *Landesvermessung und Geobasisinformation Brandenburg***
> Dezernat 43 - GDI, Kontaktstelle, INSPIRE-Zentrale
> Herr Sören Horn
> Heinrich-Mann-Allee 103 - Haus 19, 14473 Potsdam
> Mail: soeren.horn at geobasis-bb.de <mailto:soeren.horn at geobasis-bb.de>
> Tel.: (03 31) 88 44 - 247
> http://www.geobasis-bb.de <http://www.geobasis-bb.de/>
> _______________________________________________ mapserver-users
> mailing list mapserver-users at lists.osgeo.org
mapserver-users mailing list
