[mapserver-users] [ASK] Merge polygon from multiple source files
lars.schylberg at blixtmail.se
Fri Sep 18 15:18:25 PDT 2015
There is actually two ways to do this with Mapserver:
You could join them with a ogrtindex. Then You are not actually merging the polygons but that doesn't matter
since You will only display the polygon and not the outline.
To do the ogrtindex You will do something like this with a bash script
#/bin/sh
# make an ogr index file for mapserver for the S57 data
# this example shows how to do chart level 2 and DEPARE layer
DIR=.
CL=2
IFS=$'\n' read -r -d "" -a files <<< "$(find "$DIR" -name "??${CL}*.000" -type f)"
ogrtindex -lname DEPARE Chartindex_${CL}_depare.shp ${files[@]}
To display in mapserver:
LAYER
NAME DEPARE_2
TYPE POLYGON
CONNECTIONTYPE OGR
TILEINDEX "Chartindex_2_depare.shp"
TILEITEM "Location"
STATUS ON
CLASS
NAME "<= 0"
EXPRESSION ([DRVAL2] <= 0)
STYLE
COLOR 155 200 163
END
END
CLASS
NAME "0-10"
EXPRESSION (([DRVAL2]> 0) AND ([DRVAL2] < 10))
STYLE
COLOR 145 202 243
END
END
CLASS
NAME "10-20"
EXPRESSION (([DRVAL2] >= 10) AND ([DRVAL2] < 20))
STYLE
COLOR 180 218 247
END
END
CLASS
NAME "Deep water > 20"
EXPRESSION (([DRVAL2] >= 20) AND ([DRVAL2] < 30))
STYLE
COLOR 210 234 231
END
END
CLASS
NAME "Deep water > 30"
EXPRESSION ([DRVAL2] >= 30)
STYLE
COLOR 234 255 243
END
END
END # Layer
The second option to really join the depare areas is to run ogr2ogr two or three times.
(all this should of course be scripted)
First: ogr2ogr to convert all S57 DEPARE layers to shape (or sqlite ) - one by one
Second step: merge all shape files with ogr2ogr (make a loop and merge one by one)
Third step: join the polygons with a vrt file:
Something like this (file called "depare_join.vrt"):
<OGRVRTDataSource>
<OGRVRTLayer name='DEPARE_VRT'>
<SrcDataSource relativeToVRT='1' shared='1'>./combined_2_depare.shp</SrcDataSource>
<SrcSQL dialect='sqlite'>
SELECT ST_union(geometry), DRVAL1, DRVAL2
FROM DEPARE group by DRVAL1
</SrcSQL>
</OGRVRTLayer>
</OGRVRTDataSource>
The third step could be used both with ogr2ogr or directly with Mapserver
In Mapserver it would look something like this when using the vrt file directly:
LAYER
NAME DEPARE_2
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION './depare_join.vrt'
DATA DEPARE_VRT
The rest is the same in the Mapserver layer
I haven't found a good way to combine ogrtindex with vrt:s
Have fun /Lars S.
-----Originalmeddelande-----
Från: "Milis Inpo" <milis.inpo at gmail.com>
Till: mapserver-users at lists.osgeo.org
Datum: 2015-09-12 19:52
Ämne: [mapserver-users] [ASK] Merge polygon from multiple source files
I would like to find a way to merge polygon from multiple source files. I have one set of ENC S57 files which contains 13 files. I would like to extract the DEPARE layer from each file and merge it with other polygon if it is side by side and has same depth value.
Is there anyway for me to do that in Mapserver ?
TIA
Best Regards,
Tenlee
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150919/e6655769/attachment.html>
