[mapserver-users] mapscript problem
Carlos Ruiz
boolean10001 at yahoo.com
Mon Sep 21 12:46:31 PDT 2015
Ahmet,
Annotation layers have been deprecated:
LAYER — MapServer 7.0.0 documentation
| LAYER — MapServer 7.0.0 documentationEnables debugging of a layer in the current map. Debugging with MapServer versions >= 5.0: |
| View on mapserver.org | Preview by Yahoo |
NoteTYPE annotation has been deprecated since version 6.2.Identical functionality can be obtained by adding LABELlevel STYLE blocks, and do not require loading thedatasets twice in two different layers as was the case withlayers of TYPE annotation.
Update you .MAP file if or your Java code as it is suggested.
MSc. Carlos Ruiz
To: mapserver-users <mapserver-users at lists.osgeo.org>
Sent: Monday, September 21, 2015 1:32 PM
Subject: [mapserver-users] mapscript problem
hello
When I upgrade mapserver rom 6.0 to 7.0.
I encountered a new error in mapscrip-java:
" Caused by: java.lang.UnknownError: loadLayer(): Unknown identifier. Annotation Layers have been removed. To obtain same functionality, use a layer with label->styles and no class->styles"Can you tell me how this happened ?How can I solve the problem ?
regards
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
________________________
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150921/dd8338ef/attachment.html>
