[mapserver-users] Using a SRS with inverted axes.
Andrea Peri
aperi2007 at gmail.com
Wed Sep 23 13:25:56 PDT 2015
Thx Even.
A.
2015-09-23 21:02 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Le dimanche 20 septembre 2015 19:09:15, Andrea Peri a écrit :
>> Raise ticket on mapserver issue system.
>> https://github.com/mapserver/mapserver/issues/5168
> For the record, I've updated mapaxisorder.csv with EPSG v8.6 (the one I had
> available on my PC, not the latest I know).
>> Thx.
>> 2015-09-20 18:39 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
>> > Le dimanche 20 septembre 2015 17:56:32, Andrea Peri a écrit :
>> >> Hi Jukka,
>> >> I can show this two samples from an mapserver where I update just
>> >> yesterday the new proj 4.9.2 and so it support the latest epsg db:
>> >> 1)
>> >> http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsa
>> >> mba
>> >> mm&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&Typename=rt_ambamm.idco
>> >> muni .rt.poly&srsName=EPSG:6707&MAXFEATURES=100
>> >> The epsg:6707 is a epsg code with axes north, east as reported from
>> >> http://www.epsg-registry.org/
>> >> Instead the mapserver return 565347.495390 4910630.530024 (east , north)
>> >> 2)
>> >> Using the same crequest I try instead the epsg:25832 that is an epsg
>> >> code with axes (east, north)
>> >> mba
>> >> muni .rt.poly&srsName=EPSG:25832&MAXFEATURES=100
>> >> it return still return the sames 565347.495390 4910630.530024 (east,
>> >> north)
>> >> Please note both epsg:6707 and epsg:25832 are projected, instead
>> >> epsg:4326 is a geograhic system.
>> >> Perhaps mapserver invert only on geographics ?
>> > No it has a resource file mapaxisorder.csv with the list of EPSG codes
>> > where axis order must be inverted and it seems it isn't up to date. Can
>> > you raise a ticket about that ?
>> > Not sure how the CSV file was generated initially, but a script using the
>> > GDAL OSR API could do it.
>> >> Thx,
>> >> A.
>> >> 2015-09-20 17:22 GMT+02:00 Rahkonen Jukka (MML)
>> >> <jukka.rahkonen at maanmittauslaitos.fi>:
>> >> > Hi,
>> >> > You must give an exact example where it fails for you. WMS 1.3.0 with
>> >> > EPSG:4326 is using inverted axis and work with Mapserver, and you can
>> >> > see inverted axes also in the GML that comes as a response from WFS
>> >> > 1.1.0
>> >> > http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.0.0&REQUES
>> >> > T=g etfeature&TYPENAME=continents&MAXFEATURES=100
>> >> > http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.1.0&REQUES
>> >> > -Jukka Rahkonen-
>> >> > ________________________________________
>> >> > Andrea Peri wrote:
>> >> > Hi,
>> >> > I see the mapserv don't seem able to invert the axes when the invoked
>> >> > srs define the inverted.
>> >> > Is confirmed this ?
>> >> > Thx,
>> >> > Andrea Peri
>> >> > qwerty àèìòù
>> >> > _______________________________________________
>> >> > mapserver-users mailing list
>> >> > mapserver-users at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> > Spatialys - Geospatial professional services
>> > http://www.spatialys.com
Andrea Peri
qwerty àèìòù
