[mapserver-users] seemingly sucessfully compiled mapserver 7.0.1 on ubuntu 14.04 - but NO - gives binary output ?
karsten karsten at terragis.net
Tue Apr 5 09:35:45 PDT 2016
Hi All,
thanks to all the responses. It was neither one of ( cgi-bin permissions for Apache nor the Script alias) Both where in line with what everyone said/ listed. The issue was that I did not have the cgi module for Apache enabled :(
I enabled it with
a2enmod cgi
service apache2 restart
and then everything worked for mapserver, perl script etc.
I did only find out because I places a simple Perl script in cgi-bin that also was downloaded instead of executed .
Thanks for the answers they brought me on the right track !
Cheers
Karsten
  _____
From: Rahkonen Jukka (MML) [mailto:jukka.rahkonen at maanmittauslaitos.fi]
Sent: Tuesday, April 05, 2016 0:17
To: karsten at terragis.net; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] seemingly sucessfully compiled mapserver 7.0.1 on ubuntu 14.04 - but NO - gives binary output ?
I believe that there is something wrong with the configuration of your http server. It does not seem to know that you do not want to download the mapserv binary but make the binary to work for you. If you run Apache I would have a look at “ScriptAlias” in the httpd.conf file and check that the directory where you have placed the mapserv binary is configured to contain applications. This example is from Windows.
# ScriptAlias: This controls which directories contain server scripts.
    # ScriptAliases are essentially the same as Aliases, except that
    # documents in the target directory are treated as applications and
    # run by the server when requested rather than as documents sent to the
    # client.  The same rules about trailing "/" apply to ScriptAlias
    # directives as to Alias.
    ScriptAlias /cgi-bin/ "/ms4w/Apache/cgi-bin/"
    ScriptAlias /fcgi-bin/ "/ms4w/Apache/cgi-bin/"
-Jukka Rahkonen-
karsten wrote:
Hi All,
I just seemingly sucessfully compiled mapserver 7.0.1 on Ubuntu 14.04 and can getv the follwoing output  from the executable:
/usr/lib/cgi-bin# ./mapserv -v
MapServer version 7.0.1 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Howvere when I try to get a get aresponse to a request e.g. 136.243.250.62/cgi-bin/mapserv
or aslo when I try a getcapabiliteis request like
http://136.243.250.62/cgi-bin/mapserv?map=/var/www/mapdata/ccrp/mapfiles/fingermillet2.map <http://136.243.250.62/cgi-bin/mapserv?map=/var/www/mapdata/ccrp/mapfiles/fingermillet2.map&VERSION=1.1.1&REQUEST=getCapabilities&SERVICE=wms> &VERSION=1.1.1&REQUEST=getCapabilities&SERVICE=wms
I always get a 'binary file back' output like below the line . Would anybody know what could have gone wrong or where to start figuring this out ?
Cheers
Karsten
Karsten Vennemann
Terra GIS LTD
.----------------binary output below? -----------------
ELF          >    ð
@     @       P"          @ 8   @ ‑        @       @ @     @ @     ø      ø                   8      8@     8@
                    ð      ð`     ð`           (                    ‑      ‑`     ‑`     ð      ð                   T      T@     T@     D       D              Påtd   È      È@     È@     <       <              Qåtd                                                  Råtd   ð      ð`     ð`                        /lib64/ld-linux-x86-64.so.2          GNU                       GNU
O ~a¢; ¼k*BUÍš~6›   ‑         €!
ˆ @‑   "   *   j CÖºã’|(Œ
CEÕìjš|2bÛíØqX
8ò‹
ÚÍ㞸ñ
­KãÀêÓï
âž Ñ”ó                        µ                                             Ï                      š                      e                                           m                     /        –                     Y                     l                      ¥                      å                      >                       `                     9                     û                      £                     Ý                      ª                                          R                       t                     /                                          y                     ’                      b    è `             Ï    !`             ˆ     !`            ¼    ø `             ·
 $@           h
 ð
@             à    ø `                 !`            o
 @@     e       y
@             d     è `             ‘    À@            \
 ´@             R
 Ý@     G        libmapserver.so.2 _ITM_deregisterTMCloneTable __gmon_start__ _Jv_RegisterClasses _ITM_registerTMCloneTable msIO_installHandlers msFreeMapServObj msDebug loadParams msCGIWriteError msIO_fprintf msGetVersion msCGIWriteLog msSetup msGetGlobalDebugLevel msCGIDispatchRequest msCGILoadMap msAllocMapServObj msCleanup msIO_setHeaderEnabled libc.so.6 fflush exit strncmp signal puts putchar putenv stdout stderr gettimeofday strcmp __libc_start_main _edata __bss_start _end /src/ms/mapserver-7.0.1/build:/usr/local/lib::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: __libc_csu_fini __data_start __libc_csu_init msCleanupOnSignal _IO_stdin_used GLIBC_2.2.5        O         ui           ø­`                    !`                    !`        %            `                     `                   ( `                   0 `                   8 `                   @ `                   H `                   P `                    X `
           ` `                   h `                   p `
           x `
           € `                   ˆ `                    `                   ˜ `                     `                   ¨ `                   ° `                   ¸ `                   À `                   È `                   Ð `                   Ø `
           à `                   HƒìH‹Õ  H…Àtèƒ   HƒÄà              ÿ5  ÿ%Ä  ­@ ÿ%  h    éàÿÿÿÿ%º  h   éÐÿÿÿÿ%²  h   éÀÿÿÿÿ%ª  h   é°ÿÿÿÿ%¢  h   é ÿÿÿÿ%š  h   éÿÿÿÿ%’  h   é€ÿÿÿÿ%Š  h   épÿÿÿÿ%‚  h   é`ÿÿÿÿ%z  h    éPÿÿÿÿ%r  h
   é@ÿÿÿÿ%j <mailto:é@ÿÿÿÿ%25j>   h
   é0ÿÿÿÿ%b  h
   é ÿÿÿÿ%Z  h
   éÿÿÿÿ%R  h
   é ÿÿÿÿ%J  h   éðþÿÿÿ%B  h   éàþÿÿÿ%:  h   éÐþÿÿÿ%2  h   éÀþÿÿÿ%*  h   é°þÿÿÿ%"  h   é þÿÿÿ%  h   éþÿÿÿ%  h   é€þÿÿÿ%
  h   épþÿÿÿ%  h   é`þÿÿÿ%ú  h   éPþÿÿ1íI‰Ñ^H‰âHƒäðPTIÇÀ°@ HÇÁ@@ HÇÇ$@ ègÿÿÿôf­D  ¸ÿ ` UH-ø ` Hƒø
H‰åw]ø    H…Àtô]¿ø ` ÿà­€    ¸ø ` UH-ø ` HÁøH‰åH‰ÂHÁê?HÐHÑøu]ú    H…Òtô]H‰Æ¿ø ` ÿâ­€    €=y   uUH‰åè~ÿÿÿ]Æf  óí@ Hƒ=H
   t‑¸    H…ÀtU¿ ‑` H‰åÿÐ]é{ÿÿÿ­ ésÿÿÿUH‰åHƒì‰}üº    ¾    ¿    èþÿÿH‹  ¾È@ H‰Ç¸    è;ýÿÿè–þÿÿ¿    è
þÿÿUH‰åSHƒìh‰}œH‰uÇE¤   HÇE¨    è(þÿÿ…ÀtH‹E¨H‰Çè¸ýÿÿèSþÿÿ¿    èÉýÿÿè´ýÿÿƒøvHE°¾    H‰Çè^ýÿÿÇE    é‹  ‹E H˜HÅ    H‹EHÐH‹ ¾ß@ H‰Çè®ýÿÿ…Àu&èýÿÿH‰ÇèÝýÿÿH‹6  H‰Çè‑ýÿÿ¿    èTýÿÿ‹E H˜HÅ    H‹EHÐH‹ ¾â@ H‰Çè`ýÿÿ…ÀuÇE¤    ¿    è+ýÿÿéû   ‹E H˜HÅ    H‹EHÐH‹ º
   ¾æ@ H‰Çè=üÿÿ…Àu.¿ô@ èoýÿÿ‹E H˜HÅ    H‹EHÐH‹ H‰ÇèPýÿÿé    ‹E H˜HÅ    H‹EHÐH‹ ¾@ H‰ÇèÇüÿÿ…Àt(‹E H˜HÅ    H‹EHÐH‹ ¾
@ H‰ÇèŸüÿÿ…ÀuP¿@ èÑüÿÿ¿
   è÷üÿÿ¿P@ è½üÿÿ¿`@ è³üÿÿ¿˜@ è©üÿÿ¿Ð@ èŸüÿÿ¿@ è•üÿÿ¿    èüÿÿƒE ‹E ;EœŒiþÿÿ¾Ý@ ¿
   èlûÿÿ¾Ý@ ¿   è]ûÿÿèHüÿÿH‰E¨H‹E¨‹U¤‰PH‹E¨H‹XH‹E¨H‹@A¸    ¹    º    ¾    H‰Çèíúÿÿ‰CH‹E¨H‹@‹@ƒøÿu
H‹E¨H‰ÇènûÿÿëpH‹E¨H‰Çè ûÿÿH‹U¨H‰BH‹E¨H‹@H…Àu
H‹E¨H‰Çè?ûÿÿëAH‹E¨H‹@‹€H‑  ƒø~HEо    H‰ÇèéúÿÿH‹E¨H‰ÇèMûÿÿ…Àt
H‹E¨H‰ÇèýúÿÿH‹E¨H‹@H…Àt{H‹E¨H‹@‹€H <mailto:H‹E¨H‰ÇèýúÿÿH‹E¨H‹@%18H…Àt%7bH‹E¨H‹@%18‹€H> ‑  ƒø~hHEྠ   H‰Çè›úÿÿH‹EàòH*ÈH‹EèòH*Àòa  ò^ÂòXÁH‹EÐòH*ÐH‹EØòH*Èò?  ò^ËòXÊò\Á¿X@ ¸   èDûÿÿH‹E¨¾    H‰Çè³ùÿÿH‹E¨H‰Çè×ùÿÿèbúÿÿƒøvhHEÀ¾    H‰Çè
úÿÿH‹EÀòH*ÈH‹EÈòH*ÀòÒ  ò^ÂòXÁH‹E°òH*ÐH‹E¸òH*Èò°  ò^ËòXÊò\Á¿˜@ ¸   èµúÿÿè€úÿÿ¿    èöùÿÿf­D  AWA‰ÿAVI‰öAUI‰ÕATL%˜   UH-˜   SL)å1ÛHÁýHƒìè¥øÿÿH…ít‑­„     L‰êL‰öD‰ÿAÿÜHƒÃH9ëuêHƒÄ[]A\A]A^A_Ãff.­„     óà  HƒìHƒÄà         In msCleanupOnSignal.
 -v -nh QUERY_STRING= REQUEST_METHOD=GET --h --help       Usage: mapserv [--help] [-v] [-nh] [QUERY_STRING=value] Options :         -h, --help              Display this help message.      -v                      Display version and exit.       -nh                     Suppress HTTP headers in CGI mode.      QUERY_STRING=value      Set the QUERY_STRING in GET request mode.     mapserv request processing time (msLoadMap not incl.): %.3fs
   mapserv total execution time: %.3fs
        €„.A;<      xöÿÿˆ   (øÿÿX   ùÿÿ°   \ùÿÿÐ   xýÿÿð   èýÿÿ8             zR x
   È÷ÿÿ*                  zR x  $
   èõÿÿ°
F
J
w€ ?;*3$"
   D   ]øÿÿG    A
†C
   d   „øÿÿ   A
†C
Eƒ    D   „   €üÿÿe    B
E
ŽE
E
(ŒH
0†H
8ƒM
@l
8A
0A
(B
B
B
B
   Ì   ¨üÿÿ
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160405/8af944a8/attachment.htm>
More information about the MapServer-users mailing list
