[mapserver-users] How avoid overlapping of label between two distinct layers
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Aug 9 05:31:21 PDT 2016
Are you setting a fixed position (e.g. CC)? You can try AUTO and MapServer will try different placements to avoid collisions. --Steve
________________________________________
From: mapserver-users [mapserver-users-bounces at lists.osgeo.org] on behalf of Andrea Peri [aperi2007 at gmail.com]
Sent: Tuesday, August 09, 2016 7:28 AM
To: thomas bonfort
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] How avoid overlapping of label between two distinct layers
HI Thomas,
Yes, I put the FORCE=true.
But setting
FORCE=false,
mapserver will remove the label overlapping.
http://www502.regione.toscana.it/ows2/com.rt.wms.RTmap/wms?map=owscacciapesca&version=1.3.0&TRANSPARENT=true&LAYERS=rt_cacciapesca.sottoambito_atc_2015.rt%2Crt_cacciapesca.atc_2015.rt&STYLES=default%2Cdefault&CRS=EPSG%3A25832&SERVICE=WMS&REQUEST=GetMap&FORMAT=image%2Fpng&BBOX=672896.00367533,4847223.6202292,680026.94491189,4849534.2528872&WIDTH=824&HEIGHT=267
2016-08-09 14:10 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
> Mapserver will prevent label coliding by default unless you force it
> to do otherwise. I suspect that in your case one of the layers is
> either not using a labelcache, set to FORCE, or is a client WMS layer
> for which your own mapserver has no control/knowledge of label
> positions.
> thomas
> On 9 August 2016 at 14:06, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi,
>> I need to avoid the overlapping of labels between two layers.
>> To do this I try to set the BUFFER option in both layers, but I see it
>> seem don't work as I expected.
>> Perhaps the buffer is working only for label of same layers ?
>> This is a sample of actual overlapping:
>> http://www502.regione.toscana.it/ows2/com.rt.wms.RTmap/wms?map=owscacciapesca&version=1.3.0&map_resolution=91&TRANSPARENT=true&LAYERS=rt_cacciapesca.sottoambito_atc_2015.rt%2Crt_cacciapesca.atc_2015.rt&STYLES=default%2Cdefault&CRS=EPSG%3A25832&SERVICE=WMS&REQUEST=GetMap&FORMAT=image%2Fpng&BBOX=672896.00367533,4847223.6202292,680026.94491189,4849534.2528872&WIDTH=824&HEIGHT=267
>> In both layers I set:
>> LABELCACHE on
>> LAYER
>> CLASS
>> LABEL
>> TEXT 'Sottoambito [sottoambit]'
>> TYPE TRUETYPE
>> BUFFER 5
>> Thx.
>> Andrea Peri
>> qwerty àèìòù
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty àèìòù
