[mapserver-users] How avoid overlapping of label between two distinct layers
Andrea Peri
aperi2007 at gmail.com
Tue Aug 9 05:42:23 PDT 2016
Hi Steve,
I try setting
position auto
and test the results.
Thx for hint.
A.
2016-08-09 14:31 GMT+02:00 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>:
> Are you setting a fixed position (e.g. CC)? You can try AUTO and MapServer will try different placements to avoid collisions. --Steve
> ________________________________________
> From: mapserver-users [mapserver-users-bounces at lists.osgeo.org] on behalf of Andrea Peri [aperi2007 at gmail.com]
> Sent: Tuesday, August 09, 2016 7:28 AM
> To: thomas bonfort
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] How avoid overlapping of label between two distinct layers
> HI Thomas,
> Yes, I put the FORCE=true.
> But setting
> FORCE=false,
> mapserver will remove the label overlapping.
> http://www502.regione.toscana.it/ows2/com.rt.wms.RTmap/wms?map=owscacciapesca&version=1.3.0&TRANSPARENT=true&LAYERS=rt_cacciapesca.sottoambito_atc_2015.rt%2Crt_cacciapesca.atc_2015.rt&STYLES=default%2Cdefault&CRS=EPSG%3A25832&SERVICE=WMS&REQUEST=GetMap&FORMAT=image%2Fpng&BBOX=672896.00367533,4847223.6202292,680026.94491189,4849534.2528872&WIDTH=824&HEIGHT=267
> 2016-08-09 14:10 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
>> Mapserver will prevent label coliding by default unless you force it
>> to do otherwise. I suspect that in your case one of the layers is
>> either not using a labelcache, set to FORCE, or is a client WMS layer
>> for which your own mapserver has no control/knowledge of label
>> positions.
>> thomas
>> On 9 August 2016 at 14:06, Andrea Peri <aperi2007 at gmail.com> wrote:
>>> Hi,
>>> I need to avoid the overlapping of labels between two layers.
>>> To do this I try to set the BUFFER option in both layers, but I see it
>>> seem don't work as I expected.
>>> Perhaps the buffer is working only for label of same layers ?
>>> This is a sample of actual overlapping:
>>> http://www502.regione.toscana.it/ows2/com.rt.wms.RTmap/wms?map=owscacciapesca&version=1.3.0&map_resolution=91&TRANSPARENT=true&LAYERS=rt_cacciapesca.sottoambito_atc_2015.rt%2Crt_cacciapesca.atc_2015.rt&STYLES=default%2Cdefault&CRS=EPSG%3A25832&SERVICE=WMS&REQUEST=GetMap&FORMAT=image%2Fpng&BBOX=672896.00367533,4847223.6202292,680026.94491189,4849534.2528872&WIDTH=824&HEIGHT=267
>>> In both layers I set:
>>> LABELCACHE on
>>> LAYER
>>> CLASS
>>> LABEL
>>> TEXT 'Sottoambito [sottoambit]'
>>> TYPE TRUETYPE
>>> BUFFER 5
>>> Thx.
>>> Andrea Peri
>>> qwerty àèìòù
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
