[mapserver-users] mapcache question
thomas bonfort
thomas.bonfort at gmail.com
Thu Aug 25 05:55:46 PDT 2016
The reprojection is done inside MapCache, i.e. as a client of the
original tiles. You don't need an additional WMS :)
thomas
On 25 August 2016 at 14:50, Travis Kirstine
<tkirstine at firstbasesolutions.com> wrote:
> I believe that there still would be an issue as the reprojection from X to Y, the reprojection would need to be done on the source WMTS side. I guess you could proxy the source WMTS using mapserver with the gdal mini driver and reproject to create a WMS to feed mapcache?
> -----Original Message-----
> From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
> Sent: August-25-16 3:55 AM
> To: Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>
> Cc: Travis Kirstine <tkirstine at firstbasesolutions.com>; Jukka Sirviö <Jukka.Sirvio at mipro.fi>; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] mapcache question
> Jukka,
> in master, there is also support for any GDAL dataset as a mapcache source (i.e. in addition to wms). If you use that in addition to a GDAL TMS/WMS/WMTS minidriver you'll be able to reproject/store third party tiles on the fly.
> thomas
> On 24 August 2016 at 21:58, Lime, Steve D (MNIT) <Steve.Lime at state.mn.us> wrote:
>> I would think reprojection of individual tiles into another set of tiles that would stitch back together without artifacts would be difficult. I thought MapCache did support native MapServer mode=map as a source which could useful if GDAL supports WMTS and you could create a corresponding MapServer layer.
>> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]
>> On Behalf Of Travis Kirstine
>> Sent: Wednesday, August 24, 2016 1:14 PM
>> To: Jukka Sirviö <Jukka.Sirvio at mipro.fi>;
>> Jukka,
>> According to the docs mapcache only support WMS as input.
>> " A source is a service mod-mapcache can query to obtain image data. This is typically a WMS server accessible by a URL. (There are currently no sources other than WMS implemented, though others may be added later if the need arises)"
>> If this is still true then your proposed chain will not work.
>> MapProxy will support a tiled source and I know TMS works (not sure
>> about WMTS) and handle the reprojection
>> Regards
>> On Behalf Of Jukka Sirviö
>> Sent: August-24-16 10:09 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] mapcache question
>> Hello,
>> I would like to put a mapcache to be in the middle, in the following chain:
>> 1) original wmts service in local/national crs x --> 2) mapcache wmts, reprojection to world-wide crs y (3857) --> 3) user interface (OpenLayers v2, Qgis), also in crs y
>> Mapcache was compiled, and is working a-ok with demo data. But I have trouble to configure mapcache to work as a part in the above chain. As planned, Mapcache should work as a WMTS client down towards target 1 and WMTS server up against target 3, ie. kind of a proxy with crs reprojection and basic auth. Anyway, does this make any sense at all, or is the draft totally irrational?
>> If the draft is reasonable, could you give some hints on how to proceed related to configuration with mapcache.xml?
>> -Jukka
>> ________________________________
>> Tämä sähköpostiviesti (liitteineen) saattaa sisältää luottamuksellista tietoa, joka on tarkoitettu vain vastaanottajalleen. Jos et ole oikea vastaanottaja, ilmoita viestin lähettäjälle tapahtuneesta virheestä ja tuhoa viesti välittömästi. Viestin luvaton julkaiseminen, kopioiminen, jakelu tai muu käyttö tai toimenpiteisiin ryhtyminen sen perusteella on ehdottomasti kielletty.
>> This message (including any attachments) may contain confidential information intended for the person or entity to which it is addressed. If you are not the intended recipient, notify the sender and delete this message immediately. Notice that disclosing, copying, distributing or any other use of the message and its information, or taking any action based on it, is strictly prohibited.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
