[mapserver-users] Kernel Density
Dave Barter
dave at phased.co.uk
Thu Dec 1 06:59:55 PST 2016
Thanks, this has got to the nub of it as:-
SIZE 1 and SIZE 100 and SIZE 255 show no difference so SIZE is not making it in to the Kernelt density layer at all?
Dave Barter
@citizenfishy
www.phased.co.uk
> On 1 Dec 2016, at 14:56, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> Forget my datarange comment, I should have re-read the docs. I see nothing wrong with your setup, so you should be getting a different output provided you are certain your [val] attribute is effectively ranging from 0 to 100.
> You might get some insights with:
> - Try manually setting your STYLE->SIZE (0 then 100 then 255)
> - Try with AUTO normalization once you've re-enabled [val] binding
> thomas
> On Thu, Dec 1, 2016 at 3:39 PM thomas bonfort <thomas.bonfort at gmail.com <mailto:thomas.bonfort at gmail.com>> wrote:
> At a first glance your mapfile seems correct. Can you try switching your datarange to 0 50, and make sure that you are not using a tiled display on your viewer?
> thomas
> On Thu, Dec 1, 2016 at 3:27 PM Dave Barter <dave at phased.co.uk <mailto:dave at phased.co.uk>> wrote:
> Can anyone on the list help with this:-
> http://gis.stackexchange.com/questions/219669/mapserver-kernel-density-layer-weight <http://gis.stackexchange.com/questions/219669/mapserver-kernel-density-layer-weight>
> Dave Barter
> @citizenfishy
> www.phased.co.uk <http://www.phased.co.uk/>
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/mapserver-users <http://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161201/509cb94a/attachment.html>
