[mapserver-users] Mapserver 7.0.3 and disabling default extent for WFS
Even Rouault
even.rouault at spatialys.com
Mon Dec 19 14:26:44 PST 2016
On lundi 19 décembre 2016 21:46:32 CET Rahkonen Jukka (MML) wrote:
> Hi,
> I am running Mapserver 7.0.3, I have a vector layer from a quite large
> GeoPackage through OGR connection and I have set the LAYER METADATA item
> "wfs_use_default_extent_for_getfeature" "no"
> Still if I query GetFeature simply with &COUNT=1 I can see that the default
> extent is used msOGRFileWhichShapes: Setting spatial filter to 19969.99999
> 6597277.99999 749676.00001 7785300.00001 This makes count based request
> pretty slow and it take about 15 second to get the first feature.
> The documentation in http://mapserver.org/ogc/wfs_server.html says that this
> option is supported "since MapServer 7.0.3" . So what could be wrong?
Jukka,
thanks for spotting my brain damage...
In fact there are 2 issues :
- a minor one: the debug message "Setting spatial filter..." was always displayed, even when
the spatial filter wasn't applied
- a major one: the logic to interpret the yes/no value of the setting was inverted (only when it
is explicitly set fortunately, so that doesn't break existing mapfiles without the metadata
item). I've fixed that, and thus modified the doc to advertize the feature only in 7.0.4. I guess I
didn't notice that since I mixed it with other optimizations.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161219/a3081737/attachment.html>
