[mapserver-users] Mapserver 7.0.3 and disabling default extent for WFS
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Dec 19 14:34:10 PST 2016
If I set "wfs_use_default_extent_for_getfeature" "yes"
I see a difference
[Tue Dec 20 00:28:37 2016].113723 msOGRFileWhichShapes: Setting spatial filter to -1e+300 -1e+300 1e+300 1e+300
[Tue Dec 20 00:28:48 2016].950696 msOGRFileNextShape: Returning shape=9, tile=0
However, this change does not make is fast, notice 11 seconds between WhichShapes and Next shape.
-Jukka-
Lähettäjä: Even Rouault [mailto:even.rouault at spatialys.com]
Lähetetty: 20. joulukuuta 2016 0:27
Vastaanottaja: mapserver-users at lists.osgeo.org
Kopio: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: [mapserver-users] Mapserver 7.0.3 and disabling default extent for WFS
On lundi 19 décembre 2016 21:46:32 CET Rahkonen Jukka (MML) wrote:
> Hi,
> I am running Mapserver 7.0.3, I have a vector layer from a quite large
> GeoPackage through OGR connection and I have set the LAYER METADATA item
> "wfs_use_default_extent_for_getfeature" "no"
> Still if I query GetFeature simply with &COUNT=1 I can see that the default
> extent is used msOGRFileWhichShapes: Setting spatial filter to 19969.99999
> 6597277.99999 749676.00001 7785300.00001 This makes count based request
> pretty slow and it take about 15 second to get the first feature.
> The documentation in http://mapserver.org/ogc/wfs_server.html says that this
> option is supported "since MapServer 7.0.3" . So what could be wrong?
Jukka,
thanks for spotting my brain damage...
In fact there are 2 issues :
- a minor one: the debug message "Setting spatial filter..." was always displayed, even when the spatial filter wasn't applied
- a major one: the logic to interpret the yes/no value of the setting was inverted (only when it is explicitly set fortunately, so that doesn't break existing mapfiles without the metadata item). I've fixed that, and thus modified the doc to advertize the feature only in 7.0.4. I guess I didn't notice that since I mixed it with other optimizations.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161219/43b2fbc4/attachment.html>
