[mapserver-users] [SOLVED] About the WFS 2.0 stored query example
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Dec 22 00:44:22 PST 2016
Found it!
There was no linefeed [LF] after the last row of my XML file.
I found discussion that learned me that LF after each line, including the terminating one is compulsory in POSIX http://stackoverflow.com/questions/729692/why-should-text-files-end-with-a-newline. Is it is required in XML as well?
-Jukka Rahkonen-
Lähettäjä: Rahkonen Jukka (MML)
Lähetetty: 22. joulukuuta 2016 0:17
Vastaanottaja: mapserver-users at lists.osgeo.org
Kopio: Even Rouault (even.rouault at spatialys.com) <even.rouault at spatialys.com>
Aihe: Re: [mapserver-users] About the WFS 2.0 stored query example
Attached, created with Notepad++, UTF-8 without BOM, unix style end-of-lines. It does not look bad to me but perhaps there are some odd characters.
-Jukka Rahkonen-
Lähettäjä: Even Rouault [mailto:even.rouault at spatialys.com]
Lähetetty: 21. joulukuuta 2016 18:48
Vastaanottaja: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Kopio: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>; Jeff McKenna <jmckenna at gatewaygeomatics.com<mailto:jmckenna at gatewaygeomatics.com>>
On mercredi 21 décembre 2016 12:50:28 CET Rahkonen Jukka (MML) wrote:
> Hi,
> Håvard already made a doc issue, but I fear now that it is not only doc
> issue. When I tested my improved XML file I had also the inline stored
> query description active in the mapfile. I haven't had success yet with
> reading the description from file. However, this workflow works for me:
> - prepare the XML definition
> - remove white space and line feeds
> - escape all double quotes with backslash
> - copy the string into wfs storedquery inlinedef
> I was testing on Linux, Mapserver 7.0.3.
Jukka,
I suspect an issue with the text editor you used. The <?xml version="1.0" encoding="UTF-8"?> prolog line
is not needed if your XML is valid and UTF-8 encoded (it is the XML default encoding). And in the msautotest suite,
https://github.com/mapserver/mapserver/blob/branch-7-0/msautotest/wxs/data/wfs_200_allgeoms_filestoredquery.xml , there's no
such line.
Even
> -Jukka Rahkonen-
> On 2016-12-21 6:36 AM, Rahkonen Jukka (MML) wrote:
> > It was not self-evident for me. Perhaps the examples in
> > http://mapserver.org/ogc/wfs_server.html#stored-queries-wfs-2-0 could
> > have this edit for making them more copy-paste ready.
> Please file your documentation enhancements at
> https://github.com/mapserver/docs/issues Thank you.
> Wishing everyone a merry Christmas :)
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161222/b5480c2f/attachment-0001.html>
