[mapserver-users] [SOLVED] About the WFS 2.0 stored query example
Even Rouault
even.rouault at spatialys.com
Thu Dec 22 01:16:19 PST 2016
On jeudi 22 décembre 2016 08:44:22 CET Rahkonen Jukka (MML) wrote:
> Found it!
> There was no linefeed [LF] after the last row of my XML file.
> I found discussion that learned me that LF after each line, including the
> terminating one is compulsory in POSIX
> http://stackoverflow.com/questions/729692/why-should-text-files-end-with-a-> newline. Is it is required in XML as well?
Good catch. The code that read stored queries from external file accidentally replaced the
last byte read by the nil character to ensure string termination. This wasn't the expected
behaviour. Just fixed it (but indeed terminating with a LF is a good practice)
> -Jukka Rahkonen-
> Lähettäjä: Rahkonen Jukka (MML)
> Lähetetty: 22. joulukuuta 2016 0:17
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Kopio: Even Rouault (even.rouault at spatialys.com)
> <even.rouault at spatialys.com> Aihe: Re: [mapserver-users] About the WFS 2.0
> Attached, created with Notepad++, UTF-8 without BOM, unix style
> end-of-lines. It does not look bad to me but perhaps there are some odd
> characters.
> -Jukka Rahkonen-
> Lähettäjä: Even Rouault [mailto:even.rouault at spatialys.com]
> Lähetetty: 21. joulukuuta 2016 18:48
> Vastaanottaja:
> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
> Kopio: Rahkonen Jukka (MML)
> <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaito
> s.fi>>; Jeff McKenna
> <jmckenna at gatewaygeomatics.com<mailto:jmckenna at gatewaygeomatics.com>> Aihe:
> Re: [mapserver-users] About the WFS 2.0 stored query example
> On mercredi 21 décembre 2016 12:50:28 CET Rahkonen Jukka (MML) wrote:
> > Hi,
> > Håvard already made a doc issue, but I fear now that it is not only doc
> > issue. When I tested my improved XML file I had also the inline stored
> > query description active in the mapfile. I haven't had success yet with
> > reading the description from file. However, this workflow works for me:
> > - prepare the XML definition
> > - remove white space and line feeds
> > - escape all double quotes with backslash
> > - copy the string into wfs storedquery inlinedef
> > I was testing on Linux, Mapserver 7.0.3.
> Jukka,
> I suspect an issue with the text editor you used. The <?xml version="1.0"
> encoding="UTF-8"?> prolog line
> is not needed if your XML is valid and UTF-8 encoded (it is the XML default
> encoding). And in the msautotest suite,
> https://github.com/mapserver/mapserver/blob/branch-7-0/msautotest/wxs/data/w
> fs_200_allgeoms_filestoredquery.xml , there's no
> such line.
> Even
> > -Jukka Rahkonen-
> > On 2016-12-21 6:36 AM, Rahkonen Jukka (MML) wrote:
> > > It was not self-evident for me. Perhaps the examples in
> > > http://mapserver.org/ogc/wfs_server.html#stored-queries-wfs-2-0 could
> > > have this edit for making them more copy-paste ready.
> > Please file your documentation enhancements at
> > https://github.com/mapserver/docs/issues Thank you.
> > Wishing everyone a merry Christmas :)
> > -jeff
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161222/b01757c0/attachment.htm>
More information about the MapServer-users
