[mapserver-users] How can I get a customized MapCache folder structure with several dimensions as subfolders
thomas bonfort thomas.bonfort at gmail.com
Mon Feb 1 11:20:06 PST 2016
Carola,
If you are willing to try out the master branch you can specify the keys in
the disk template as {dim:dimname}, I.e. in your case:
/path/{dim:year}/{dim:month}/etc..
Make sure to read the migration-guide.txt as the syntax to define
dimensions has changed a little.
Thomas
On Feb 1, 2016 12:33 PM, "Carola Kaiser" <ckaiser at cct.lsu.edu> wrote:
> Hello,
> I am using MapServer 7.0 with MapCache and would like to customize the
> cache storage directory structure by using several dimensions as subfolders.
> The goal is to get a cache folder structure like:
> C:/ms4w/tmp/ms_tmp/cache/{YEAR}/{MONTH}/{DAY}/{z}/{y}/{x}.{ext}
> Here is what I have tried in my mapcache.xml file:
> 1.       Use the <base></base> absolute path
>    <cache name="disk" type="disk">
>       <base>C:/ms4w/tmp/ms_tmp/cache/</base>
>    </cache>
>    <source name="vmap0" type="wms">
>    </source>
>    <tileset name="test">
>       <source>vmap0</source>
>       <cache>disk</cache>
>       <grid>WGS84</grid>
>       <format>PNG</format>
>       <dimensions>
>                 <dimension type="regex" name="YEAR"
> default="2016">^[0-9]{4}$</dimension>
>                  <dimension type="regex" name="MONTH"
> default="00">^[0-9]{2}$</dimension>
>                 <dimension type="regex" name="DAY"
>       </dimensions>
>    </tileset>
> This works pretty nice but the final folder structure is:
> C:/ms4w/tmp/ms_tmp/cache/test/WGS84/{YEAR}/{MONTH}/{DAY}/{z}/{y}/{x}.{ext}
> How can I get rid of the test/WGS84 folders?
> 2.       Use the cache template tag
>    <cache name="disk" type="disk" layout=”template”>
> <template>C:/ms4w/tmp/ms_tmp/cache/{YEAR}/{MONTH}/{DAY}/{z}/{y}/{x}.{ext}</template>
>    </cache>
>    </source>
>       <cache>disk</cache>
>       <grid>WGS84</grid>
>       <dimensions>
>       </dimensions>
>    </tileset>
> The template does only allow me to concatenate all dimensions like
> {YEAR}_{MONTH}_{DAY} but not to create a subfolder name from each dimension:
> Is it possible to customize the cache folder structure and how can I
> achieve this? Any help is very much appreciated!
> Thanks!
> Carola
> Carola Kaiser, IT Consultant & GIS specialist
> Center for Computation & Technology
> Louisiana State University
> e-mail: ckaiser at cct.lsu.edu
> CERA: http://coastalemergency.org
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160201/a3911c78/attachment.htm>
More information about the MapServer-users mailing list
